07-13-2010, 10:35 PM | #881 |
btw cause I'm to lazy to look is there a way to make the 3rd or 4th channel a three position monitory switch? As in hold=on release=off, and opposite for the other way |
07-13-2010, 10:51 PM | #882 |
07-13-2010, 11:04 PM | #883 |
I wanna be Dave Join Date: Oct 2005 Location: Under the 4444
This thing seems like it'll do anything I want it to do and I'm almost sold just one question. Say I'm on the way home from a comp after standing in the sun all day, I'm tired, feeling lazy and the garage opener is in the glove box but the 4pk is laying on the passenger seat in arms reach. Can I program it to open my garage door? That would be Awesome! On a serious note and I'm sure it's been covered but what is the major difference between the 2 4pk's? Last edited by slowrockr; 07-13-2010 at 11:13 PM. |
07-13-2010, 11:11 PM | #884 |
07-13-2010, 11:54 PM | #885 | |
I will have to ask if I can post the exact differences I will say that the case is a little different because they changed out the little D-pad type control deal, some people had a hard time with it. One thing I am not sure on is if the new radio will ship with the new smaller RX's or not. I am trying to get all these answers as quickly as possible, Futaba Japan is just kind of hard to get answers from I guess. | |
07-14-2010, 08:47 AM | #886 |
Rock Crawler Join Date: Aug 2005 Location: Illinois
The new 4PKS will come with the new smaller receiver. ETA for the 4PKS is some time in Sept. J |
07-14-2010, 08:49 AM | #887 |
07-14-2010, 09:55 AM | #888 |
RCC Addict Join Date: Jun 2005 Location: Prosser
07-16-2010, 05:21 AM | #889 |
Rock Crawler Join Date: Oct 2008 Location: Italy
| Harley, this is my wiring diagram, can you tell me if it is ok? |
07-16-2010, 05:27 AM | #890 |
07-16-2010, 05:29 AM | #891 |
07-16-2010, 05:36 AM | #892 |
because i have 2 battery, one linked to esc with one motor, other battery linked to bec and to other esc splitting red and black wire from battery..and both red esc wire that go to receiver cutted.. do you understand, a diagrame would be better ehehe |
07-16-2010, 05:54 AM | #893 |
| I do not recommend two batteries. I suggest running the setup as I show. I will not be available to do a diagram anytime soon.
07-16-2010, 05:59 AM | #894 |
why did you reccommend me one battery instead of 2 battery? one battery is better to operate current, to operate escs? |
07-16-2010, 06:32 AM | #895 |
now i have 2x tp 850 3s 45c, can i use them or with only battery i have to move to higher amperage such 1300 mhp or higher?
07-16-2010, 07:51 AM | #896 |
07-16-2010, 12:09 PM | #897 |
ok Harley, this evening my friend and i weld the electronic as you you suggest me by the diagram with only battery and then i start to set up my 4pk.. thanks again |
07-17-2010, 02:57 PM | #898 | |
Quarry Creeper Join Date: Mar 2009 Location: Fairfield, Cali
Looks like I can use this channel in any of these: 1. Optional servo to perform forced suspension articulation, 2. Optional servo to do rear cutting brake, or 3. Front and rear electronic ESC kill switch to easily do front and rear dig while retaining my mix function. I am not sure if this will get faster dig switchover using one switch. Last edited by axelram; 07-17-2010 at 11:16 PM. Reason: spell check | |
07-21-2010, 09:02 AM | #899 |
Good morning Harley, i set my radio 4pk as you show on this post and i use 2x tekin fxr and 2x hh35, hyperion switching bec.., jr ds 6301 yesterday i tested for firt time my berg and i noticed that sometimes front and rear don't go with the same speed, sometimes when i go reverse rear end don't turn and after 1 sec he start turning and sometimes also front end has this problem, i check connexion between pinion and gear for front and rear and they are ok but i noticed that one pole of capacitor of front esc is not linked, i have to solder again, can it do some problem, capacitor is a accumulator of current? thanks in advance. Angelo |
07-21-2010, 09:28 AM | #900 | |
Getting a Berg perfectly setup is some what of an art.
The wheels will most likely move at slightly different speeds if you have the car off the ground but this won't be noticable when driving as long as everything else is set as described. Everything else is going to be in the setup of the car not in the programming of the radio. I would suggest reading on the topic in the berg section for further info. Anything else in regards to the radio just ask here Quote:
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
