09-12-2010, 08:21 AM | #2241 | |
| Yeah that sucks. I ran a 500 Puller on 2S lipo for a couple years and tried it once on 3S lipo, it lasted for 15 seconds. Looks just like yours does, with the winding fried in half like that. Quote:
Depends which two steering servos you're using. I know it can handle one HiTec 7950 and a 5245 servo fine, but asking it to handle two 7950 servos might be pushing it (for example). So it depends would be my answer. You can always try it, it'll either work or not. If not, buy a Castle BEC. | |
09-12-2010, 07:44 PM | #2242 |
Rock Stacker Join Date: Feb 2010 Location: winnipeg
what do you replace a motor with that irreplaceable ? |
09-13-2010, 03:47 AM | #2243 |
I have 14t armatures here still. If the magnets aren't messed up too bad, you can just put in another arm.
09-13-2010, 10:53 AM | #2244 |
Quarry Creeper Join Date: Oct 2008 Location: In the basement...
Hi - Quick question on suggested timing for my 35T handwounds on 3S (BR-XL) for a Berg... I think I'm currently running 0 F & R I believe... Thanks, Chris |
09-13-2010, 10:57 AM | #2245 |
6 degrees of advance is good, but you can run them at zero as long as they do not arc.
09-13-2010, 11:11 AM | #2246 |
09-14-2010, 09:10 AM | #2247 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
JRH, Hyperion EOS0606I I got from you will safely charge all LiFe batteries right? |
09-14-2010, 09:14 AM | #2248 | |
As long as you got it within the past two years, yep! | |
09-14-2010, 01:12 PM | #2249 | |
Is a serial number I should verify against or is there something in the settings I should see (or not see)? Last edited by Locked Up; 09-14-2010 at 01:24 PM. | |
09-14-2010, 01:47 PM | #2250 |
Look for LiFe mode, or a sticker on it that says a123 compatible. The cells shouldn't be charged more than 3.7v per cell. If you wanted to visually monitor the charge, you could always just stop it when the cells got to 3.7v each.
09-14-2010, 02:15 PM | #2251 |
Rock Crawler Join Date: Aug 2006 Location: nc
what lipo charger do you recomend for a micro. also what batery for around 35 -40 mins of crawl time?
09-14-2010, 02:16 PM | #2252 |
A losi micro? It depends on the battery you are using. I don't have experience enough with the micro to recommend a pack for that runtime.
09-14-2010, 02:22 PM | #2253 |
yes the losi micro crawler. from what i read i need a 2s 450 but i dont know what brand. thats the nly lipo im going to need charging so i dont need a real fancy charger.
09-14-2010, 02:30 PM | #2254 |
Hit up cheap battery packs, they can help you out with a nice and inexpensive pack and charger recommendation.
09-14-2010, 05:32 PM | #2255 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
John, I got a 400 11t Puller in a trade a few weeks ago. What was this motor setup for, whats the biggest rig (setup) I could put it in. Ran a search for them on here and your site, can't find anything. Also looking for the right battery/ESC setup.
09-15-2010, 01:18 PM | #2256 |
RCC Addict Join Date: Jun 2008 Location: Fresno
hey john i just put in an order for two 45t motors but i forgot to add "the matched motor timing option" would i be able to add the service? *sorry but i wont be able to respond until tommorrow afternoon |
09-15-2010, 01:25 PM | #2257 | |
Paypal $2 to paypal @ holmeshobbies.com (take out the spaces) and I will take care of you What rig? | |
09-15-2010, 10:07 PM | #2258 |
Thanks! |
09-16-2010, 04:09 PM | #2259 |
09-17-2010, 11:32 AM | #2260 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
John, A totally off topic question here. But could you make or have made a top quality 29mm BL outrunner in the 2800-3200kv range? I want to put HH power in an RC jet |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
