09-30-2010, 09:40 AM | #2301 |
Rock Crawler Join Date: Oct 2008 Location: Italy
09-30-2010, 10:44 AM | #2302 |
Pebble Pounder Join Date: Sep 2008 Location: CNY
Sorry if this has been asked.. but whats a good waterproof brushed esc with drag brake? I wanted to run an AI Runner esc in my scx10 but my friend says I should really look for something with drag brake..? I will mostly be trail running, not climbing.. and I want something submersible for stream crossings |
09-30-2010, 11:08 AM | #2303 | ||
They are so small that rebuilding them does not always work. There just isn't much comm material to work with. Generally a new armature and brushes will do it. Quote:
10-01-2010, 09:50 AM | #2304 |
Ever since switching to the 4pk and a dual esc set-up I have noticed that when I dig on a vertical I get a slight rollback on my rear axle. my setup on my 5.5lb truck: 4pk HH 40t Epic motors Dual FXRs 850 mah 3s 45c lipos I run a "correct" gear mesh front and back. I know that tightening my mesh would probably help some, but is there anything else that I can do? I don't like running a tight gear mesh. This annoying rollback has cost me a few reverse penalties. |
10-01-2010, 10:26 AM | #2305 |
Otherwise no change in your setup? Does the drag on the rear activate when you are in neutral throttle? If you dig the front, is the drag letting go on the rear?
10-01-2010, 10:48 AM | #2306 | |
Yes the drag does activate when there is neutral throttle and it works very well. I will dig the front so I can make a breakover and the rear axle will slip a bit. I can also dig the front on flat concrete and the rear axle will slowly follow almost like I have my rear motor turned down to 30-40%. These motors were just rebuilt before Nationals, including cutting the comms and new brushes. I hoped doing that would help the situation but it didn't. | |
10-01-2010, 11:25 AM | #2307 |
If you have turned your drag down, you will just have to turn it up to prevent the rollbacks. If it is a motor issue, swapping motors would help you pinpoint that. |
10-01-2010, 10:31 PM | #2308 |
Rock Crawler Join Date: Sep 2009 Location: Temecula Ca
| pineon
piņon gear or spur gear can I use the stock one our ill i need to change it I'm ruining a stock hpi crawler king and up grading to your hh combo. man I wish I could spell wright even spell check cant help me |
10-02-2010, 03:50 PM | #2309 |
John i sent you a e mail to your web site address.
10-05-2010, 10:11 AM | #2310 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
Dear John, I messed up. I was bashing around w/o a motor guard and I have broken off one of the motor tabs on a 35T TM. i could get it to work by jamming my knife in there, but once i tried to solder it, the tab broke off, and my motor no worky. how can i fix this? |
10-05-2010, 10:18 AM | #2311 | ||
10-05-2010, 10:35 AM | #2312 |
Yes sir. I have already soldered the wire there, but the motor still will not go! its like it gets no power...... based on the tab that broke off, what part of the circuit could be broken? |
10-05-2010, 10:58 AM | #2313 |
Your brush could be hanging. If the motor took a whollop that is likely. Maybe the brush hood is bent too.
10-05-2010, 11:21 AM | #2314 |
well, the brush wire got ripped up the other day.... just re-soldered it and it works........ i can just get a brush @ the LHS right? |
10-05-2010, 12:35 PM | #2315 |
Yep! Guidetti- I will have some 55t motors done tomorrow for you |
10-05-2010, 01:56 PM | #2316 |
Quarry Creeper Join Date: Jul 2005 Location: Santa Clara
10-05-2010, 02:17 PM | #2317 |
Must have missed that, sorry. The 20 or 25t will haul ass on 4s, but it will wear out fast, like needing a comm cut every run. Puller motors are discontinued as of right now, but I have some brushless versions in the works that should be done soon. I also have some samples coming that will be a rebuild of the puller in brushed, but that is likely a few months out. |
10-05-2010, 02:20 PM | #2318 | |
10-05-2010, 02:37 PM | #2319 |
10-06-2010, 02:51 AM | #2320 |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
