09-17-2010, 12:01 PM | #2261 |
29mm Od? Never off topic in here...
09-17-2010, 12:53 PM | #2262 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
yes sir 28.8mm-29mm Od mounting holes wold have to be spaced @ 16mm and 19mm to work w/ most 70mm EDF units i mean, if im gonna sup up my jets, I want HH power if at all possible. the flyboys dont know what they are missing. |
09-17-2010, 01:12 PM | #2263 |
There isn't anything I could get produced quickly for that application, but I could recommend this motor or similar http://www.innov8tivedesigns.com/pro...bc4f4dc8a142fd |
09-17-2010, 01:18 PM | #2264 |
you're the man John, Thank you.
09-17-2010, 01:19 PM | #2265 |
They have longer and shorter versions available too, depending on the wattage and frame you may need to fit.
09-18-2010, 05:01 AM | #2266 |
Quarry Creeper Join Date: Nov 2005 Location: Australia
Hi, Im about to place an order for 2x Tekin FXR's and 2 TorqueMaster Pro HandWounds for an XR-10 (front steer only) Not being very good with electronics or wiring, is there anything else i need so i can hook this all up? Do i need any extra wiring, Y harnesses, deans plugs etc? Will i need a Y harness if i use Punk Dig (till i upgrade radio's to something like a 4pK). Will i be able to run dual ESC's with a TQ3 with a modded 3 way switch? Thanks. Last edited by davway; 09-18-2010 at 05:04 AM. |
09-18-2010, 08:33 AM | #2267 |
You will need some deans plugs, and probably some extra wire depending on your setup needs. I am not familiar enough with the punk to know how best to wire it in. A tq3 won't be able to mix channels, so a punk dig on the tq3 will be the better setup until you upgrade to a mixing radio. |
09-18-2010, 10:33 AM | #2268 |
Rock Stacker Join Date: Apr 2009 Location: Italy
Hi John, your opinion is requested and of course if you want, post 10. The Italian Nano Tracer Thanks. |
09-19-2010, 06:57 AM | #2269 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
| Awe crap it finally gave up.
hey john, after 18 months of incredible service from your motors I broke one, It looks to have thrown a winding. I broke 3rd gear and fourth gear at LCQ and I guess it was just too much horsepower. Any way Should I send Both motors in for a overhaul? If so what is the process? Thanks for the awesome motors and your continued HONEST support of the crawling world.
09-19-2010, 07:20 AM | #2270 |
If you want to get back two motors that are closely matching, send em both in and I will see what it takes to repair them. You may need a new armature on the broken motor. 716 W. Sexton rd. Columbia, MO 65203 Last edited by badger; 06-21-2012 at 11:25 AM. Reason: address change |
09-19-2010, 02:45 PM | #2271 |
Quarry Creeper Join Date: Nov 2007 Location: Alberta canada
Hey john, I am having an issue with your 540 torquemaster pro's, 35T I had one a while ago that I killed the comm on, it developed flat spots between the "comm sections" and eventually just died. I chalked it up to me probably setting the timing wrong. I bought another one recently, read how to adjust the timing properly again, set it to 7* and then broke the motor in a bit. I pulled it apart today and found that the flat spots are starting to come back, but not as severely yet. You can see on the closest side of the comm that it is starting to get rough. Am I setting the timing wrong, or is there something else wrong? |
09-20-2010, 10:08 AM | #2272 |
What voltage are you running? Could just be running them hard. They do wear, being a brushed motor. Looks like you are due for a comm cut.
09-20-2010, 12:34 PM | #2273 |
John, I have a couple 540 35t TM's comin in for my XR10 this week. What is the proper break in procedure? |
09-20-2010, 12:55 PM | #2274 |
They have serrated brushes, so you really don't need to break them in. If you want to seat them proper, run them at 2.5v for about 10 minutes.
09-20-2010, 12:57 PM | #2275 |
nice. ive never spent more than $20 on a motor. Im so excited! |
09-20-2010, 06:34 PM | #2276 |
| I am running 3s lipo, and that comm has 1.5 battery packs through it. I did get some dirt in the motor, so that might have done it. I'm just concerned that I am setting the timing wrong or something, I don't want to end up with flat spots in my comm again.
09-21-2010, 06:49 AM | #2277 | |
the 11t cobalt 454 have 3300Kv that at 7.4V give "24420" rpm, you think that can support 3S battery? "36560" rpm with the 3S it is a little too much compared the "32630" that I have now whit the mongoose and I like the response with that speed, which is the correct "T" of your cobalt 454 to reach the same speed that I have now? I hope you can understand my "maccheroni" english!!! Ciao. | |
09-21-2010, 08:17 AM | #2278 | ||
I do not recommend the 11t 454 Puller to be used with 3s. | ||
09-21-2010, 07:14 PM | #2279 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
When will you have the non pro cc becs back in stock? Cheers Kieren |
09-21-2010, 08:41 PM | #2280 |
Waiting on Castle for those, they have been backordered for a few weeks now. Hopefully within a few weeks I would say.
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
