04-30-2018, 04:37 PM | #441 |
| Re: 3d printer for rc parts |
04-30-2018, 04:51 PM | #442 |
Rock Crawler Join Date: Nov 2014 Location: Dells
| Re: 3d printer for rc parts https://www.ebay.com/itm/130mm-x-160...gAAOSw05taTuwU Fits perfectly, leave access for the screws still. He has ones that almost fit perfectly(factory cut wrong) for $13 too. Bit of a pia to get at the screws on those. I use mini binder clips to hold it down. Someone else was using double sided tape, but IDK about that... I switched to a v6 head at the same time and it was within 1 turn on the screws for height. The stock screws aren't quite long enough for the factory head, but could be replaced with longer 3mm countersunk screws. Springs/etc are all long enough |
04-30-2018, 05:02 PM | #443 | |
Pebble Pounder Join Date: Feb 2016 Location: Shelby
| Re: 3d printer for rc parts Quote:
This one here https://www.thingiverse.com/thing:1808029 Last edited by moondaddy; 04-30-2018 at 05:07 PM. Reason: Found thing | |
04-30-2018, 07:20 PM | #444 | |
Rock Crawler Join Date: Mar 2016 Location: Murphy
05-01-2018, 09:05 AM | #445 | |
https://www.buildtak.com/product/bui...xplate-system/ The magnetic base will help keep the stock heated bed from warping. If you heated bed is badly warped, you should replace it before doing the FlexPlate System. | |
05-01-2018, 09:55 AM | #446 | |
05-01-2018, 07:08 PM | #447 |
Stupid extruder motor took a crap. Then the one I bought was slightly longer and didn't fit. They should have offset it to not interfere with the Z axis rod. At least I have the one piece Z axis stepper motor/rod in now. The V2 has the nema17 holes already drilled out. |
05-01-2018, 08:37 PM | #448 | |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
Sent from my Nexus 5 using Tapatalk | |
05-01-2018, 08:58 PM | #449 |
yes
05-02-2018, 09:35 AM | #450 | |
05-02-2018, 11:48 AM | #451 |
| Re: 3d printer for rc parts Not long enough... I bought a replacement on amazon for $13. I'm not 100% sure it's the motor, but Ill find out tomorrow.
05-02-2018, 11:54 AM | #452 |
| Re: 3d printer for rc parts If you have the stock heat bed, it comes with a BuildTak surface that is glued to the heat bed. With the BuildTak FlexPlate system, you attach a magnetic base to the heat bed which is used to hold down a removable spring steel plate. The spring steel plate has a BuildTak sticker on it. When you are done printing, you take the plate off and flex it to remove the print. Here is the video that explains it: Adding the layers of the magnetic base and spring steel sheet helps reduce warping of the heat bed. The downsides: The 114x114 kit is 6 mm smaller than the 120x120 build plate and the kit costs $40 plus shipping. |
05-02-2018, 12:08 PM | #453 |
05-02-2018, 12:57 PM | #454 |
05-02-2018, 01:08 PM | #455 |
05-03-2018, 11:37 AM | #456 |
Anyone play with this yet? Just curious, I like how I can skip a part if its failing and keep printing the other stuff instead of scrapping the whole job. Printrun: Pure Python 3d printing host software Im bored at the real job so browsing around for a way to run a slicer of some sort directly from an android tablet. Im not looking to go the full Pi setup or wifi. It would be nice if I could grab my files off my drop box, run them through 'a' slicer on my android tablet and pit the gcode out directly to the machine either USB or through a SDCard setup. Anyone know a way? |
05-03-2018, 12:24 PM | #457 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
Time start some calibrations. | |
05-03-2018, 07:08 PM | #458 |
Figured out my extruder issues. The heatbreak was sloppy in the heatsink, causing it to overheat and partially plug. Used thermal paste on the threads and everything looks to be working properly again. Stupid Chinese tolerances. |
05-03-2018, 08:45 PM | #459 |
My new Y plate arrived today hopefully tomorrow I can get it installed. |
05-04-2018, 06:35 AM | #460 | |
Sounds more then just tolerances. Did you check the thread piece that screws into the hot end? Maybe something happened to the teflon sleeve inside and is allowing heat creep? Is your fan coming on correctly and/or at all? My heat sink is cut in half, I only half 5 fins of it compared the full stepper size it was. Fan blows on it but even thats modded to hang near it and not on it. Thermal paste is more to equal heat over an area out, not really dissipate it or keep an area cooler. | |
3d printer for rc parts - Similar Threads | ||||
Can your printer do this? | CREEPERBOB | Chit Chat | 19 | 10-14-2011 07:33 PM |
Are you a printer in OH or know someone who is? | Phatmac | Ohio | 5 | 02-20-2009 02:14 PM |
