05-10-2018, 08:11 AM | #481 | |
| Re: 3d printer for rc parts Quote:
It is great to see that we have another MK3 owner here! The mk3 is a really nice printer. I am not sure if you know about it, but firmware version 3.2.0 was officially released today. It re-enables linear advance and has improvements to the xyz calibration process. Keep printing and posting. | |
05-10-2018, 12:44 PM | #482 | |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
05-10-2018, 05:33 PM | #483 | |
I do get that re-calibrating isn't something to look forward to and it takes a lot of Haribos to get through it. When upgrading to 3.2.0 you should do a factory reset and re-calibration. I recorded the Live Z setting and used that number for the first layer calibration. The first layer was still good with the same number after the upgrade. My upgrade path was 3.1.3 to 3.2.0-RC2 to 3.2.0. I skipped RC1 due to the PINDA probe height change and problems with getting the first layer right again. | |
05-11-2018, 08:46 PM | #484 |
| 3D Printer Anatomy: 50 parts in 5 minutes
A good video that explains most of the terms used for 3d filament printers. |
05-11-2018, 09:17 PM | #485 |
Rock Crawler Join Date: Nov 2014 Location: Dells
And I got a sensor failed error again tonight. octiprint keeps going like nothing happened so it never gave any errors on there. Same issue where the hot end temp went awal and then shut off. |
05-15-2018, 05:27 PM | #486 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
Anyone having issues with Cura 3.3.1 Appimage under MintLinux 18.3? Downloaded the Appimage, moved it to my Home directory, made it executable. When I click on it the black Cura screen appears, show loading various modules, gets to initializing interface sits there for a few seconds, the black box disappears and that is as far as it gets. Cura 3.2.1 loads just fine, thought maybe I had a bad download so I deleted it and downloaded a fresh copy and had the same issue. |
05-24-2018, 07:27 AM | #487 |
Pebble Pounder Join Date: Jan 2018 Location: Spain
As this is the 3D print thread I think I should mention this here as well: I designed a Super that most parts are 3D printed. If someone is interested now it is open source (License: CC BY-SA 3.0) - You can access to the CAD files of this project here: https://cad.onshape.com/documents/27...1cbb92cec77030 - You can see the design just clicking on the link. - You need and Onshape account (it is free) in order to be able to copy, modify, export, etc. the design. - The CAD file will change and improve as time passes, it is more tested and ideas from others are added to the design. Here is the link to the Thingiverse project where you can download all 3Dprintable parts directly on STL and where I will upload assembly instructions and other relevant info: https://www.thingiverse.com/thing:2924761 |
05-25-2018, 06:40 AM | #488 |
Rock Crawler Join Date: May 2018 Location: USA
If youre serious about 3d printing I STRONGLY recommend buying Simplify3D. Gets rid of all the troublesome parts of Cura and other budget slicers.
05-25-2018, 10:17 AM | #489 |
| Re: 3d printer for rc parts |
05-25-2018, 10:26 AM | #490 |
I strongly recommend against S3d now, I bought it and the last update destroyed the utility. The latest versions have junk pathing, doesn't handle single width extrusions, and the program will not work if you don't connect to an internet connection frequently. The program itself is more of a data harvesting program than a slicer at this point. Cura and Slic3r have better pathing now, and are free. If you want to use S3d, get the cracked version. Don't waste money on a company that is putting more time into refining data harvesting when they need to be refining the pathing. I mostly use Slic3r. I use an old S3d version on occasion when absolutely forced. I can get faster prints with higher quality from Slic3r in 95% of the cases. Anything with a single width extrusion, might as well forget about s3d completely. |
05-25-2018, 10:31 AM | #491 | |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
Sent from my Nexus 5 using Tapatalk | |
05-25-2018, 10:32 AM | #492 |
05-25-2018, 10:41 AM | #493 |
05-25-2018, 11:30 AM | #494 |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
I bought simplify3d yesterday because I was tired of constant Cura headaches, and am so far unimpressed. It has preloaded profiles for a whole lot of printers, and that's the biggest plus I can think of so far. Worked ok for my Maker Select V2, didn't see the huge print improvements several S3D fans claimed I would get. Tried it on a Replicator 2 we got in at work and the build area is WAY off center (like several inches). Doesn't really seem any easier than Cura so far.... Glad I can get a refund within the first 2 weeks.... Sent from my SM-G930V using Tapatalk |
05-25-2018, 12:27 PM | #495 | |
The cracked version I had of Simplify was older so I was a bit curious if it got better or smoother but sounds like it hasnt. | |
05-25-2018, 12:51 PM | #496 |
I'm running a Monoprice Maker Select V2, and the old Monoprice-branded version of Cura that shipped with the printer worked fine and I was able to get usable prints. The newer versions just seem to be fighting me, it seems like there's always some issue with my prints. It's quite possibly user error. I was trying S3D hoping the preset profiles for the printer would be close enough that I would only have to make minor adjustments, so far that has not been the case.... Sent from my SM-G930V using Tapatalk |
05-25-2018, 01:44 PM | #497 | |
Unless you have the need for manual supports or want the cool layer simulation I would get the refund. My favorite slicer is still Cura but there are other options: Slic3r PE which has enhancements over stock Slic3r. You can get the MK1 config files that would work with the i3 clones here: https://github.com/prusa3d/Slic3r-settings. ideaMaker is gaining in popularity and you can find profiles for Maker Select V2. | |
05-25-2018, 02:02 PM | #498 | |
You can check the build thread here: Crazy axles idea design | |
05-25-2018, 05:06 PM | #499 |
What do I need to adjust here, this is a 200x200 print to test the bed tram (level). Guessing there is an adjustment somewhere to correct this. The printer is a PowerSpec Duplicator i3d Plus (Wanhao rebrand) |
05-25-2018, 05:11 PM | #500 |
I used Linux so the slicers are a little different than the Windows versions. I have never been able to get my head around Cura and the current version won't even load for me. Have messed with Slic3r some but nothing serious. I ran across Craftware and have been pretty happy with the results. Found a setup for it it on Youtube and tweaked it a little and been having good results. One thing I like is that it has Undo for those of use that mess up.
3d printer for rc parts - Similar Threads | ||||
Can your printer do this? | CREEPERBOB | Chit Chat | 19 | 10-14-2011 07:33 PM |
Are you a printer in OH or know someone who is? | Phatmac | Ohio | 5 | 02-20-2009 02:14 PM |
