07-28-2021, 03:34 PM | #141 |
Pebble Pounder Join Date: Jun 2014 Location: Central Texas
| Re: G-Speed Rigs Only |
07-28-2021, 03:38 PM | #142 |
Pebble Pounder Join Date: Dec 2008 Location: Close
08-07-2021, 07:13 PM | #143 |
Rock Crawler Join Date: Aug 2020 Location: In The HIVE
MY Honey Comp Crawler with custom cage and some nice goodies and still tweaking the setup but runs nicely am now trying to figure out how to get the Kimbrough 62t Spur on this 2.0 low without rubbing the driveshaft! do I need a FMM or just swap the gears or flip the Transmission???? Anyway a couple pics of this Sexy Nectar Loving Rig Enjoy...... BUZZZZZZZ........
08-11-2021, 01:11 PM | #144 |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
| G-Speed Rigs Only
Here is my submission that I picked up off a member last fall. The build sheet was as follows : HC stainless links Salinas Low Overdrive Trans 62t Spur 3 Bros 2000kv Yellowjacket 12t pinion Sidewinder micro 2 Esc Hi Tech 7950TH servo TGH winch/servo mount Modded Big bore shocks SCX 10.2 axles with aluminum CHubs Incision driveshafts Bent metal fab bumpers PL Hyrax Pred Compound on Gearhead Wheels Pretty fun rig out of the box that wasn’t well suited to my rock environment the way it originally sat. An example of my rock walls. My initial impressions: Love the overdrive trans. The front end just eats the rocks. This made me revisit the OD/UD on my Trx4. At first I felt the combo was too much but now they’re both in again. The Yellowjacket was ok at best. It wasn’t hard to bog it down and drag brake didn’t seem real strong. The 12t pinion was not to my liking. The HiTech servo was run straight to Esc set at 7.5v. No BEC. Did ok, but I felt the motor and servo were pretty taxing on the ESC. I’d get the occasional brown out when in a rough spot. The front bumper was no bueno in my environment. Zero bump and glide on rocks. So I needed some changes. Ordered a Crawlmaster Pro 10T for the Trx4 that I fell in love with. Awesome awesome. Unfortunately, no way that’s fitting with the Salinas trans and chassis though. So I got a HH magnum Stubby 11t and threw a 9t pinion on. HiTech servo was replaced with direct power. I cringed at the thought of my squawky svh500 v3 on a quiet rig so I put on my first direct power a 3Bros G13. Good deal, nice and quiet Front bumper went in favor of IERC Stubby Toro with a mild stinger. Now we’re talking. Bump and glide is back. We are NOW in business for my environment. Overall the system seems much happier with the servo stress off the ESC. Magnum Stubby is very very nice. Low speed control and drag brake are much much better. 9t pinion is much better than the 12 tooth it came with. Although I wish it was as slow as my 550 10T with 9t pinion in the Trx4, but that can be axle gearing too. Servo is nice and quiet and actually increased EPA with no issues. Here is a quick vid I took of shakedown 2 with new items. Sorry about quality. (If your in Trx4 section, you’ll notice I say that a lot) https://youtu.be/7-MOuxtGvo0 I noticed the gear whine was loud and motor was warm after video so I redid mesh and ran it for a while on a block. Noise was better and motor stayed cool, so we’ll see on next run Very very happy now. Last edited by Benp; 08-12-2021 at 08:53 AM. |
08-15-2021, 05:27 PM | #145 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
Heres my gspeed v3 build. Mamba x esc HH PP 2700kv trx4 shocks Nitro pro 550oz servo 3bros servo winch Flysky gt5 rx/tx SSD offset front axle with o/d VP pro rear axle VP VFD trans with stock o/d VP 310 method 1.9 beadlocks PL hyrax 1.9 4.75 tires Ierc front n rear bumpers Sent from my SM-A516V using Tapatalk |
08-16-2021, 07:03 AM | #146 | |
| Re: G-Speed Rigs Only Quote:
Very nice GSpeed BUZZZZZZZ........ | |
08-16-2021, 08:01 AM | #147 | |
08-17-2021, 02:53 AM | #148 | |
I was able to bog the motor down when the rig was in questionable spots. I’ve never experienced that before with my heavier Trx4. I noticed the drag brake was not as strong as my other motors. Once I tasted a good brushed motor with the Crawlmaster Pro I wanted nothing to do with the Yellow Jacket any more. Magnum Stubby was my only option with the Salinas trans. Last edited by Benp; 08-17-2021 at 06:26 AM. | |
08-17-2021, 10:56 AM | #149 | |
This rig is light but the cage adds the most weight even though its not that heavy... Maybe I can use the Yellowjacket In the future on a smaller scale build!!!! BUZZZZZZ....... I prefer brushed over brushless too even though the 1.9 rigs are mainly using the brushless esc's and motors I still like the quiet motor and loud Steel Spur gear..... BUZZZZZZZ..... | |
08-18-2021, 03:55 PM | #150 | |
No, I left the CC Sidewinder Micro 2 in for the initial runs with new setup. I have a HH BRXL that I’m going to swap in, so I’m excited to see if there’s a difference with the Sidewinder Micro 2. Last edited by Benp; 08-18-2021 at 05:16 PM. | |
08-19-2021, 10:02 AM | #151 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
Some awesome builds popping up in here. Very impressive. Keep up the killer work everyone. Here’s my latest gspeed build. This one is a rear portal with a front Ssd Diamond axle. Similar to my rear portal sherpa but different transmission and this one will be a smidge longer. Good progress so far but a few things to do still. A new panhard link on the way from hardcore Rc (original links were tnt but needed a different panhar), need to order a new rs800v2, pick up some tires and foams, and then finally body work. Also picked up some element kit shocks from a friend and through some Traxxas gts TiN shafts in the shocks. Perfect fit. Also added a Traxxas x ring to the bottom of the lower cartridge while I was in there. |
08-19-2021, 02:57 PM | #152 | |
08-21-2021, 09:18 PM | #153 |
RCC Addict Join Date: Mar 2011 Location: easton
I ordered a Gspeed v3 chassis kit along with the dual servo mount, and hard body sliders. I am looking to run ar45p axles with a mojave body. Do you know if I will be able to use links that are made for the v1 c1 chassis? Sent from my iPhone using Tapatalk |
08-21-2021, 10:33 PM | #154 |
| Re: G-Speed Rigs Only I believe u do use the same links. The only difference i can tell between the v1c1 n v3 chassis is that the v1c1 has shock towers that use hardware to attach them. Where as the v3 shock towers are cut out with the chassis as one piece. Just need the links for the proper wb length of the body
08-25-2021, 04:07 PM | #155 | |
Sweet thanks. I ordered links for the v1c1 and I’ll report back if they work or not. If not I have an excuse to build a v1c1 and a v3 Sent from my iPhone using Tapatalk | |
08-28-2021, 10:19 PM | #156 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
I just took some chassis comparison shots for another member, and I can say the front upper link mounting location is much different between the two. And with the back side of the skid being higher than the v1c1 it may change the pinion angle some. But it may only require some minor tweaks Sent from my iPhone using Tapatalk |
08-28-2021, 10:23 PM | #157 |
Anybody interested in printing some electronics trays I designed for the v3 chassis? I was thinking about putting the file on thingiverse, but I would like someone to give it a test run on their own machine before I do. I’ve printed a few sets and used them for myself, but I’m not sure my printer is perfectly calibrated. Sent from my iPhone using Tapatalk |
09-01-2021, 01:33 PM | #158 |
Pebble Pounder Join Date: Aug 2018 Location: US
About to step out of my RTR comfort zone and build a custom rig. I have a Element I'm going to use as a donor vehicle and it will get a HW Axe system with a ProTek 370TBL servo. |
09-01-2021, 03:15 PM | #159 |
That will be a real good setup! I was lucky enough to get a set of CF rails during the g-speed YouTube giveaway, those are either going to be built with my Capra as a donor, or I will snag the new element builders kit 2. Look forward to seeing more. |
09-02-2021, 12:55 PM | #160 |
Base chassis complete and donor gutted. Now to go through and replace all the hardware with stainless and wait for the rest of my parts. |
G-Speed Rigs Only - Similar Threads | ||||
TF2 Transmission: R3 2-speed vs R3 single-speed vs R4 single-speed | Panther6834 | RC4WD Trail Finder 2 | 9 | 11-05-2019 12:40 PM |
tf2 with 2 speed transmission and 2 speed transfer case | Teasley4Crawlers | RC4WD Trail Finder 2 | 9 | 12-02-2014 10:34 AM |
F350 3 speed to single speed conversion, tips/ideas needed please | neo | 1.9 Scale Rigs | 10 | 02-11-2010 02:49 PM |
single speed setup vs. speed control | traxxas junky | Electronics | 18 | 08-28-2007 11:28 PM |
