10-05-2012, 07:21 PM | #121 |
Rock Crawler Join Date: Dec 2011 Location: Northwestern PA
| Re: AX10 Class 3 scaler Bronco build, cont'd
Today, fender flares installed: |
10-05-2012, 09:53 PM | #122 |
RCC Addict Join Date: Mar 2010 Location: RC Addict Garage
Flea sized screws? Sent from my DROIDX using Tapatalk 2 |
10-05-2012, 09:56 PM | #123 |
Oh and I had a thought. When you make your cage hinge it in the back soy you can flip the while lid up to get to batteries and stuff. Course I know some folks charge en right in the truck. Sent from my DROIDX using Tapatalk 2 |
10-06-2012, 07:43 AM | #124 |
| Re: AX10 Class 3 scaler Bronco build, cont'd |
10-06-2012, 06:25 PM | #125 |
I got to spend one or two glorious hours in the garage this afternoon. It was cold outside, a little sunny, quiet in my house, and an absolutely perfect time to be in the garage. It was wonderful. I started on the interior. My material of choice is some 1/4" plywood I had lying around. Normally, I don't like to use wood on a scale or regular size vehicle; it seems like plastics and metals are more appropriate (except for things like a wooden truck bed). However, I already had this 1/4" plywood, it is fairly strong, very light, and easy to deal with. Also, I plan to paint it so hopefully it won't be obvious that it's actually wood when I'm done. After much careful measuring, I cut the following piece for the interior floor: In thinking of how to mount it, I wanted to use mounts that resembled actual body mounts on a 1:1 size vehicle: Attached to the mounts: I also got to make the firewall before I had to call it quits for the day: I feel like it went well, and I'm looking forward to getting back at it. I plan to do a wall at the rear of the interior and a dash. Then I'll need to come up with seats, and cover the tranny and flywheel. |
10-06-2012, 06:49 PM | #126 |
Rock Crawler Join Date: Oct 2011 Location: Warren
Nice. I like that you are using wood. I never thought to use wood for an interior. I am sure that it will work out well and it is something that is very easy to work with. I am going to keep that in mind when I build.
10-06-2012, 07:24 PM | #127 |
Dang. I'm in trouble. Sent from my DROIDX using Tapatalk 2 |
10-06-2012, 09:24 PM | #128 |
Thank you guys. Here are my thoughts on the dash: |
10-06-2012, 09:29 PM | #129 |
Pebble Pounder Join Date: Sep 2012 Location: San Francisco Bay Area
That's pretty cool. Are you gonna make a dash or buy one?
10-07-2012, 12:39 AM | #130 |
| Re: AX10 Class 3 scaler Bronco build, cont'd I am sure he is gonna make it. Great job josh it is coming out really well. I can't wait to are what you come up with for seats. I am sure you will figure it out. If you.need some ideas check out team threesix seats. I was gonna make some like this for the bug. And still might. We will have to see what the future holds. |
10-07-2012, 06:04 AM | #131 |
I still think you should have flipped that tranny. More room for seats if it's flipped. Sent from my DROIDX using Tapatalk 2 |
10-07-2012, 07:21 AM | #132 |
The plan is to make the dash. Not sure about the seats yet. Tin has a pair of RC seats I need to check out, or I might make some. |
10-07-2012, 07:56 PM | #133 |
Newbie Join Date: Aug 2004 Location: Cleveland OH
Gorgeous looking rig mate!
10-08-2012, 05:37 AM | #134 |
Thanks man |
10-08-2012, 08:34 PM | #135 |
Today I made a piece for the dash, and a rear wall for the interior. I also bolted the pieces of the interior together. The erector set pieces will be painted the same color as the wood, in time. I bought a couple cell phone holder seats from Tin. I love the size of them; they fit the truck good: Next.....a pair of cabinet doors for my wife, then cagework! |
10-08-2012, 09:09 PM | #136 |
Looks good. Those seats seem to fit really well.. Are you gonna stick with those size tire/wheel combo or switch to a 1.9?
10-08-2012, 09:18 PM | #137 |
Thanks I intend to keep these wheels and tires. I wouldn't mind some more realistic looking wheels, like something RC4WD would make, but I wouldn't spend the money unless I found a good deal. This is my class 3 truck, so you can run tires up to 5.5" tall, I think. The concept for this rig is big, modified for the trail, not something you'd see on the street. The tires are going to rub a little, but I'll work it out.
10-08-2012, 09:40 PM | #138 | |
| Re: AX10 Class 3 scaler Bronco build, cont'd Quote:
10-09-2012, 04:31 AM | #139 |
That looks awesome josh. Can't wait to see it finished.
10-09-2012, 04:55 AM | #140 |
Wow those seats fit perfect. Aren't you gladi kept all this crap laying around? Sent from my DROIDX using Tapatalk 2 |
AX10 Class 3 scaler Bronco build, cont'd - Similar Threads | ||||
LNC class 2 scaler build thread | Josh_Br | Team Losi Comp Crawler | 78 | 03-27-2014 08:49 AM |
RCROCIN's Class 3 Bronco Build | RCROCIN' | 2.2 Scale Rigs | 24 | 07-17-2012 01:59 PM |
PinchFlat's Reign Labs Bronco Class-2 / Trail Build | PinchFlat | 1.9 Scale Rigs | 84 | 03-20-2011 12:39 AM |
Bronco 2.2 Scaler X trail chassis build | crawlbe4youwalk | 2.2 Scale Rigs | 20 | 10-09-2008 12:42 AM |
DTrail12 C-Channel Scaler build... 'The New Bronco' | Cake Eater | 2.2 Scale Rigs | 44 | 10-29-2006 03:57 PM |
