11-26-2013, 02:31 PM | #301 |
Rock Crawler Join Date: Jan 2011 Location: At home
| Re: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL
When all stars line up correctly .... it will happen one day A summer comp it probably will have to be, as the fall and winter comps are not for me considering I have RA. Well changed my mind about the rear shock mount position at the chassis. I tried to start with something different ... BUT ... I ended up with the exact same setup as my current one on the OG SuDu. I moved the shock back to the lower row and the hole closet to the center of the chassis. I felt bellyclearance was a bit too much and the total stance of the rig too high ... no pics |
11-26-2013, 06:32 PM | #302 |
Rock Crawler Join Date: May 2010 Location: Belfield NSW Australia
Nice work Ronald :thumbup: ill be keeping a eye on all the FL builds as im still running the sudu one v2 and I sure sooner or later ill be going FL Sent from my GT-I9505 using Tapatalk |
11-27-2013, 02:34 AM | #303 |
RCC Addict Join Date: Jun 2009 Location: Australia
Nice work mate. Are the wheels you got one of my designs or yours just out of curiosity. Sent from my GT-I9300 using Tapatalk |
11-27-2013, 03:00 AM | #304 |
Rock Stacker Join Date: Feb 2009 Location: Amsterdam The Netherlands
The pics and the build are top Ronald ,i order the parts by RC4WD for the new tranny for my rig today Jan(SuDo Clan Holland) |
11-27-2013, 09:54 AM | #305 | |
| Re: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL Quote:
Mine is based on the original Queen design (page 7), I altered the slots to loose weight and the V2.1 Queen was Born (page 13). When I send he file to Tomi he also mentioned they look like a design you made. The position off the crossbraces in the design is different I believe ... | |
11-27-2013, 10:50 AM | #306 |
Thres only so many variations available and alot do look alike. Your original design is similar though the internal spoke design is quite different. The LW version is very close to my 10 spoked design, is ok as both designs look great . Sent from my GT-I9300 using Tapatalk Last edited by Oz Bruiser; 11-27-2013 at 11:02 AM. |
11-27-2013, 11:04 AM | #307 |
I agree only that many ways .... They do look very much a like, lucky we are on the same team ... As mentioned the screwposition is different in both designs. Are you still making new designs ? |
11-27-2013, 11:50 AM | #308 |
I havent done anything new for a good while now. Just alot more busy with worrk and family and not as much time to spend on the hobby unfortunatly Sent from my GT-I9300 using Tapatalk |
11-30-2013, 04:20 PM | #309 |
I recognize your situation, life can get busy from time to time I Always say life and family comes first, that's what makes having a fun hobby possible. Good second (or third ?) place for RC crawling though You will find your time again, I am sure mate I made some spaghetti today, those are for me and some fellow teamdrivers ... bon appetit |
11-30-2013, 10:53 PM | #310 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
They are pretty Ronald! Carbon spaghetti would go great with my sudu 1 build;). I need to read more on weight loss and strength on these carbon uppers. I use TI right now. Homework for tomorrow I guess.
12-01-2013, 04:08 AM | #311 |
Quarry Creeper Join Date: Feb 2009 Location: French Guiana
| Re: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL |
12-01-2013, 04:35 AM | #312 |
Thanks guys I use tube 4mm, with .75mm wall thickness Last edited by Haastnooit; 12-01-2013 at 06:11 AM. Reason: typo |
12-01-2013, 04:58 AM | #313 |
For link, tube are sufficient. I use only rond CF for steering link, because it can receive shocks and to prevent that it is crushed |
12-01-2013, 05:22 AM | #314 |
RCC Addict Join Date: Oct 2008 Location: Finland
I also used 4mm cf tube for upper links on my 2.2 Pro all last season with no issues.
12-01-2013, 05:34 AM | #315 | ||
A set of 4 CF links for the FL comes in at 15 grams. Last edited by Haastnooit; 12-01-2013 at 06:18 AM. Reason: got to read back better before posting ;-) | ||
12-01-2013, 06:57 AM | #316 |
On my Margouillat Ar60 I have 150mm upper link in rear (e2e) and 115mm in front. These are the links longest that I manufactured and for the moment no problem, but I do not have any concern With alu ball, you gain more gramme. Generally my links weigh 5/6g (for 2 links) with aluminum ball, or then, gravity is less strong close to the equator… it is possible or my balance weight is crappy… |
12-01-2013, 07:24 AM | #317 |
Being close to the equator has effect on gravity, at the largest diameter of the earth the centifugal force off earth spinning is countering the gravity more and make the gravity value less However my scale has an accuracy of only 1 gram And is a bigger influence on accuracy I think. Using alu balls will shed about 2-3 gram a set, bringing me close to your measurements Don't think I will throw the alu balls in just now ... kinda bounded by budget ... BUT ... you got to have future plans anyways Last edited by Haastnooit; 12-01-2013 at 07:26 AM. |
12-01-2013, 11:51 AM | #318 |
Slooooow progress only as I am waiting on some parts before I can really get on with it. I am eagerly awaiting the NCD tranny to be able to finalize the drivetrain. I got some MIP driveshafts in my spare parts I want to use. I ordered some P-clips .25" (6mm) few days back that should be here soon. So next update probably will be a mounted Crawllife Grafix Xciter body. Tonight I installed the CF upperlinks only ... |
12-01-2013, 01:28 PM | #319 |
Found another little thing to do I just finished installing the RcBros KW holders for stock Axial XR10 knuckles. They are loaded with one .125" full ring and two .125" half rings, total 1.5oz (45 gr) per knuckle. |
12-01-2013, 01:29 PM | #320 |
Rock Crawler Join Date: May 2011 Location: SoCal
I've had failures with both CF tube and solid CF rod links. The tube cracked at the ends, releasing the long set screws. The solid rod never actually failed, but straight links started to bend and stay bent. My short front links have held up, but I had to replace the longer rears with Ti or aluminum. Might work for you, but just sayin'...keep an eye out. BTW, it seems odd to me you would go so light on your links and then use MIP driveshafts. Last edited by WAM; 12-01-2013 at 01:35 PM. |
Tags |
axr10 axle, sudu, suduone, xr10 mod |
Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL - Similar Threads | ||||
Haastnooit's YTC Secret Agent 3.5 | Haastnooit | Axial XR10 | 85 | 04-24-2022 12:04 PM |
Team NCD Su Du One | Oz Bruiser | Axial AX-10 Scorpion | 132 | 12-21-2013 04:34 PM |
NCD SuDu one crawler | douwe | Videos! | 2 | 11-28-2012 02:36 PM |
Mini AXR10 Axles?... | justinart24 | Tools, and Procedures | 6 | 10-15-2012 09:28 AM |
Haastnooit's Old Skool YTC BJ4 | Haastnooit | Axial XR10 | 15 | 09-02-2012 06:57 AM |
