05-18-2013, 03:04 PM | #201 |
Rock Crawler Join Date: Jan 2011 Location: At home
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne
Thanks Ben Currently running 76 gram total knuckleweight ... do you use any (an how much) ? Yeah ... real curious on performance with all the XR10 mods and other upgrades. But I have to be patient, cause it is going to take a bit of time for my electronics to get back to me ... |
05-26-2013, 01:04 PM | #202 |
Minor update, my electronics are almost "half" done ... they made it to Batt.man 4 days ago Hoping turnaround will be soon ... |
05-26-2013, 01:58 PM | #203 |
Rock Stacker Join Date: Feb 2009 Location: Amsterdam The Netherlands
I hope it so for you Ronald |
05-28-2013, 09:49 AM | #204 |
Thanks Jan ... electronics are on the way back to me |
05-28-2013, 02:15 PM | #205 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
I just received my pm about my electronics today also. I'm hoping by weeks end. I can't wait to hear how this truck performs.
05-31-2013, 08:51 PM | #206 |
Quarry Creeper Join Date: Oct 2010 Location: Land of the Cactus
Get your electoronics back yet? Im dying to see a vid of this badboy doing work. Im about to start in on the front ax axle so it can receive the creation fab wide splined tube. Pretty much followed your entire axle parts list with the exception of plastic knuks and chubs, i went aluminum. Awesome write up on the mods, very simple to follow with great pics, look forward to seeing more |
06-01-2013, 03:08 AM | #207 |
No ... I am in Europe so things will take longer .... Hoping they arrive soon though .... Don't forget the extra screws to secure the tubes to the axle, they are not shown in the first posts but you can see them clearly in post 40 on page 2 |
06-01-2013, 09:35 AM | #208 |
Rock Crawler Join Date: May 2011 Location: SoCal
Man, eleven pages and it's not running yet. That's what I call documentation. I've only occasionally visited as my SuDu is a one-off Losi adaptation so a lot of stuff doesn't cross over. But I liked mine enough that I decided to update my AX10 Gatekeeper to a SuDu so just finished re-reading your thread from Post 1. Nicely done. Only one relevant comment. I checked out your link technique and being lazy made mine much simpler -- and learned some things. Appears you don't need internal threads in the ends. They're plenty strong without. I skipped the bleed hole and found that was a mistake with superglue. It setup before I could work the end into place. But with epoxy, I didn't need the bleed hole. I had plenty of work time to get them perfect. The bad news is since the SuDu requires longish rear links, I found my rear uppers are subject to buckling. Not to the point of failure, but I can see a bend developing. This was with 4mm CF rod and Revos. The lightest fix I can think of for this is changing to 5mm CF rod and turning down the ends back to 4mm for the joints. While I like your front axle plate setup, I'm going to initially try Tomi's under-slung servo plate. RCbro used one of Tomi's plates with an underslung, reverse-mounted servo for a BTA setup. I gotta give that a try. But the steering link shapes will be a nightmare. No CF here. |
06-02-2013, 10:48 AM | #209 | |||
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne Quote:
I used 4mm CF tube, with tube the breatherhole is definately needed to let escape the otherwise compressed air inside the tubes ... I have heard about the buckling effect before, I will give them a go and see how the CF upperlinks hold up ... I like new experience Quote:
06-11-2013, 11:00 AM | #210 |
Pony express get those electronics to you yet? I had to give a sweet thread a bump |
06-11-2013, 03:03 PM | #211 |
Pony's don't swim very fast ... haven't got it yet |
06-13-2013, 04:25 PM | #212 |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne Well … electronics showed up yesterday. Turned out a disappointing evening … I couldn’t get good acces to the link button on the RX to establish a bind between the R2106GF and my 4PL, so had to unpack the smashjob … Once unpacked I could make a bind only to find out the RX would loose it at random and every time when the RX moves away more then 3 feet from the TX ? I ended up decasing a SR300 and shrinkwrap everything together temporarily to be able to run the car with the DX3E of my “retired” BJ4. I will redo the electronics when I am able to get a new R2104GF receiver and servo … Did some shakedown lines on my small rockpile in the backyard, checking if cleanup and adjustments are needed. Next week I will have time to do some serious testruns … Last edited by Haastnooit; 06-14-2013 at 04:03 PM. Reason: typo |
06-14-2013, 05:05 AM | #213 |
Hi Ronald,you did it very nice,its looks good see you soon, i call you next week Jan (Dutch SuDu Clan) |
06-26-2013, 04:27 PM | #214 |
Rock Crawler Join Date: Feb 2013 Location: york
Ronald I've been following your build for a while now and I must say you have one of the nicest rigs ive seen so far! Thumbsup! If you dont mind me asking what does your front axle measure from wheel mounting surface to wheel mounting surface? Sent from my SPH-L900 using Tapatalk 2 |
06-27-2013, 09:18 AM | #215 |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne |
06-27-2013, 06:58 PM | #216 |
Thank you! Keep up the great work Sent from my SPH-L900 using Tapatalk 2 |
07-04-2013, 03:18 PM | #217 |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne Last week I had some good time to run my SuDu
I spend a lot of time on the testpile tweeking my setup, testing a few different shock- and link positions, and taking care of some minor
BUT
annoying issues. It was a fun week and now she drives very well and is fully set for the bigger rocks at my favorite spot
Some random pics on the testpile |
07-04-2013, 06:27 PM | #218 |
RCC Addict Join Date: Jun 2009 Location: Australia
Looking good Ronald. Look forward to sone comp pics or taking on bigger rocks Sent from my GT-I9300 using Tapatalk 2 |
07-05-2013, 05:01 AM | #219 |
verry nice pics Ronald
07-06-2013, 01:54 PM | #220 |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne I hit the rocks today, nice weather and lots of fun. My buddy and me got in a good 3 hours of crawling, chichatting, some beer zipping and fair amount of good laughs. His rig is stock AX10 rtc that got its ass whooped over and over and over and
so on . No match at all, big win of all his loosing and wining about it is; my bud is finally convinced his rig needs upgrades. I brought it home with me to turn in it in to a SSS-R for him. I am sure he will like it as he likes things different from mainstream. My SuDu ran great, no issues at all I will be looking in to changing the ride height a bit, think I am bellydragging a bit too much Some progression shots of different lines taken today: Another line |
Tags |
axr10 axle, sudu, suduone, xr10 mod |
Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL - Similar Threads | ||||
Haastnooit's YTC Secret Agent 3.5 | Haastnooit | Axial XR10 | 85 | 04-24-2022 12:04 PM |
Team NCD Su Du One | Oz Bruiser | Axial AX-10 Scorpion | 132 | 12-21-2013 04:34 PM |
NCD SuDu one crawler | douwe | Videos! | 2 | 11-28-2012 02:36 PM |
Mini AXR10 Axles?... | justinart24 | Tools, and Procedures | 6 | 10-15-2012 09:28 AM |
Haastnooit's Old Skool YTC BJ4 | Haastnooit | Axial XR10 | 15 | 09-02-2012 06:57 AM |
