12-07-2012, 05:13 PM | #2361 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
| Re: GT3B Hack Question and Answer Thread
losikid sorry I have another question, I have two 3b's one hacked which I just picked up and got working and the other is stock which I've been using for a couple years. The stock one I use a Futaba style charger to keep my Nimh's charged in the radio, works great, now my question is I'm gonna hack that one two and won't have a new vr on it for a while can I still charge my batts that way after it's hacked?
12-07-2012, 05:17 PM | #2362 |
All the hack does is change the firmware....the charging circuit is all hardware
12-07-2012, 05:21 PM | #2363 |
| Re: GT3B Hack Question and Answer Thread |
12-08-2012, 01:54 PM | #2364 |
Rock Stacker Join Date: Jan 2012 Location: North Delta
Have a GT3B, running 0.6.1, been using it for a while, and for the price, I"m 100% happy with it. Only thing is I have this strange phantom problem with the center trims on the ESC's. I have this in a XR10, running dual Axial AE-2's. Both have come out of a scaler and were working fine, Both have been calibrated to the TX both independantly, and I"ve done it at the same time as well. I always end up with the same issue. Forward, reverse, all the dig functions are exactly where I like them, but for some reason every once in a while something changes. When I try and lock up the rear, the rear wheels end up turning really slowly forward, maybe 10% power getting to them, it does not matter where the throttle is, when I have the dig button down, I can control the front wheels perfectly with the transmitter, but the rear will stay turning at about 10% power. It feels like the center trim is out of whack on the rear engine when I have the rear locked up. Push the dig switch the other way to lock the front and it does the exact same thing, rear works fine, but the front will creep forward at a constant 10% power until I release the switch. Try driving it with everything set at neutural, no dig and it all works perfectly. I mess around with it for a couple hrs trying to reprogram it, after enough messing around I stumble across a setup that'll work, but then after a couple weeks, I get lazy, turn everything on too fast, trigger the ESC calibration by accident and it throws everything out of whack again. Once again, not faulting the radio at all, I know there's something off about the AE-2 and it's neutural position. But where exactly do I go into the programming to set the neutural position on ch2 and ch3 for specifically when the dig is active? |
12-08-2012, 02:08 PM | #2365 | |
| Re: GT3B Hack Question and Answer Thread Quote:
GT3B Hack Question and Answer Thread | |
12-08-2012, 02:16 PM | #2366 |
Thanks for the quick response and link. I'll get my hands on a volt meter and go from there.
12-08-2012, 06:10 PM | #2367 |
Newbie Join Date: Aug 2012 Location: fort campbell
Hello everyone, i know posted this question before but i thought i would give it another shot in case someone else has run into the same problem. I'm having trouble binding my hacked GT3C to the 6ch rx i have. I have followed losikids instructions to the letter, I Plug the bind plug into the Bat port, Then Power the rx thorugh any of the other Ports, Then Click and hold the Bind button on the radio, Then Turn the radio on, I get the solid red light, Then I let off bind button, pull out the bind plug, And then pull power to rx and shut off tx, When I turn the rx and tx back on i get nothing, no red light what so ever. When power is turned on to the rx it lights up for a split second and then nothing. I have tired this on 2 other rx multiple times without any result. I have tired binding them through every power source, (rx battery, esc, bec, etc.) I'm to the point that i'm willing to send my tx and rx to someone and pay them to hopefully fix it. This is literately driving me insane. |
12-08-2012, 11:22 PM | #2368 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Did you push bind button on rx? The one you use stick poker for? | |
12-08-2012, 11:40 PM | #2369 |
12-08-2012, 11:43 PM | #2370 | |
12-09-2012, 11:25 AM | #2371 |
12-10-2012, 02:23 PM | #2372 |
12-10-2012, 02:26 PM | #2373 |
So losikid do you think all three rx might be bad? If so do you know where i can pick some new ones up, i can't find any 6ch rx in stock anywhere.
12-10-2012, 03:59 PM | #2374 |
Its possible...i don't think its the radio. I'm not sure where to get 6ch rx's...ebay is probably your best option |
12-10-2012, 03:59 PM | #2375 |
12-10-2012, 04:18 PM | #2376 |
Okay i got an update on my Rx issue. For the hell of it i thought i would see if the two 6ch receivers i got for the GT3C would bind to my Turnigy 9x i use for fly since FlySky make the same Tx. Well they bound find to the 9x just fine, so I'm guessing something is wrong with my hacked GT3C. Its just weird because when i first hacked my GT3C the receivers bound fine. Also when i try to bind the 3ch FlySky Rx the GT3C it seems like it binds fine until i turn the Rx and Tx back on, I just get a slow steady blink light. So my thought is maybe the Rx isn't receiving the Tx signal? Who knows, maybe i just need to pick up a new hacked Tx for losikid.
12-10-2012, 04:39 PM | #2377 | |
What happens when you try the bind process w/out pressing the bind button on the radio? | |
12-10-2012, 04:50 PM | #2378 |
Hey Losikid, I checked the antenna and it is still soldered to the board. I tired the bind process with out using the bind button and nothing happens the red light just keeps blinking fast. It goes solid if i use the bind plug and bind button. Maybe the bind isn't being saved when i turn off the Rx and TX?
12-10-2012, 06:49 PM | #2379 | |
12-10-2012, 07:45 PM | #2380 |
Batteries in the Tx and Rx are fully charged.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
