12-29-2012, 06:22 PM | #2441 |
| Re: GT3B Hack Question and Answer Thread
I kinda like the snot green color. I'd be interested in it hacked with port installed so I can update with my existing programmer. I'll email you.
12-29-2012, 06:53 PM | #2442 |
Newbie Join Date: Dec 2012 Location: Oxford
Hi guys I Jst installed a ezrun 25a esc and I dunno if I damaged the antenna or my receiver but my gt3b has lost all it's ranger I cud easily drive the car 200ft away and now it's less than 10?!? I've tried another radio and it's fine Any ideas what I have dun?? The esc had got no throttle signal protection which can't be turned off, I've resoldered the antenna in the receiver and that hasn't worked either It's driving me insane! Thanks Mike |
12-29-2012, 11:34 PM | #2443 | |
Quarry Creeper Join Date: Nov 2009 Location: Central Arkansas
12-31-2012, 10:16 AM | #2444 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
Ok radio is hacked and I personalized it abit to tone down the puke green I think I can live with it for now. Sent from my DROID3 using Tapatalk 2 |
12-31-2012, 10:49 AM | #2445 |
Interesting, until now, most GT3C's I've seen have been ORANGE, a few others were Silver or "Gunmetal Grey". You & LosiKid have the only 2 "OD" green ones thus far. Do you/did you have a GT3B? If so, how do they compare?? |
12-31-2012, 10:54 AM | #2446 |
I have both and have used my gt3b for two years and I love it the gt3c feels better built in my opinion though but I would take either. Sent from my VTAB1008 using Tapatalk 2 |
12-31-2012, 02:39 PM | #2447 |
I kinda like this better, I pulled the metal plate off the top, skuffed it good and sprayed it with bedliner paint. Whatcha think? Sent from my DROID3 using Tapatalk 2 |
12-31-2012, 03:40 PM | #2448 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: GT3B Hack Question and Answer Thread Quote:
Seriously? Well personally I think it looks like crap. Don't care for the green or the silver decal removed. That and axial decals make it look like some cheap axial offered radio. You asked. Lol and this is me being nice I'm fond of the orange one really. I got some plans for that one when I decide to pick up another. | |
12-31-2012, 03:45 PM | #2449 |
Well thanks for your opinion I wouldn't go as far as to say it looks like crap but I like it better than the puke green. Sent from my DROID3 using Tapatalk 2 |
01-01-2013, 04:07 PM | #2450 |
Quarry Creeper Join Date: Mar 2012 Location: New Jersey, USA
Anyone seen this problem? After I turn on the GT3B transmitter, after a short time the back light goes out, you can still see the lcd readout but it is frozen on whatever was the last screen you were in. The buttons do nothing, and turning it off is the only way to un-freeze it. If I turn it back on it does the same thing but even quicker. If I let it sit (cool down) for a while it will come on again but start the whole issue all over again. Help! lol It has been upgraded to the 6.1 firmware. Last edited by Spidernad; 01-01-2013 at 09:35 PM. |
01-01-2013, 09:28 PM | #2451 | |
01-01-2013, 09:34 PM | #2452 |
| Re: GT3B Hack Question and Answer Thread |
01-01-2013, 09:38 PM | #2453 |
Yea, i'm confused, i don't understand what your explaining, need more info...
01-01-2013, 09:40 PM | #2454 |
01-01-2013, 09:54 PM | #2455 |
It takes about 20-30 seconds to shut down (freeze up) on the first start up, once it does it the first time it will need to cool off for a while or it will just freeze right away if I turn it on again.
01-01-2013, 10:16 PM | #2456 |
I just put the stock firmware back in and it seems OK. I'll try v0.6.1 again and see if it's OK. Before it would shut off so quick I couldn't re-program it
01-01-2013, 10:48 PM | #2457 |
I tried to read the current tab with the ST visual programmer and it gave me the "can't communicate with the radio" error (something like that), so I figured I must have had a bad solder joint on the 4 pin header. I re-soldered the 4 pin header and reprogramed it with v0.6.1 firmware and it seems fine now. Wheww! Looks like it's time for a better soldering iron! EDIT: I think with the bad solder joint, it may have corrupted the v0.6.1 firmware when I first reprogrammed it, and that was causing it to freeze up when the backlight would go out, or at other random times. Last edited by Spidernad; 01-01-2013 at 11:00 PM. |
01-04-2013, 04:27 PM | #2458 |
Newbie Join Date: Aug 2012 Location: Boston
How do i make the thrid channel 3 pos...i looked and i coildnt find it! I want to use th 3racing winch. A link would be helpful! You can pm if u want |
01-04-2013, 04:38 PM | #2459 | |
2-What firmware are you running (since the firmware version sorta determines the process)? | |
01-04-2013, 05:53 PM | #2460 |
| Re: GT3B Hack Question and Answer Thread Edit: Oh, it's a stock radio. Hmmm.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
