04-22-2013, 01:21 PM | #2781 |
Rock Crawler Join Date: Aug 2012 Location: Koloa boy 808 2 DA 206
| Re: GT3B Hack Question and Answer Thread
that helps I have a brushed 13t holmes motor on mu scx 10 thanks!
04-22-2013, 07:39 PM | #2782 |
Rock Crawler Join Date: Oct 2012 Location: Casper
No problem.
05-02-2013, 06:49 PM | #2783 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
Got a hacked gt3b this evening. Got a 3ch for the sc10 and a 6ch for the crawler. So far I have figured out by reading in this thread that I had to add all the channels so I could get past 3. No problem. My crawler has a 2-speed trans in it along with 4ws. This is where I am at Ch1 steering (good) Ch2 throttle (good) Ch3 shift servo, it operates on the "back" button on top. Usable but not what I really want. Ch4 rear steer Ch5 future winch I would like this on the D/R switch Ch6 future lights, these on the "back" button would be perfect. I would like to get the steering mix of front,rear,4ws,crab on the 3ch switch in the handle but can't get it. Can't even get it there when the steering servo is plugged into the 3ch port on the rx. I also want the shift servo on the ch3 trim button if possible. Any help would be much appreciated. Thanks |
05-02-2013, 08:39 PM | #2784 |
The answers are in this thread. Post #2 covers most of it. Although it could use a little update for 0.6.1 info. What firmware are you running? These are what I used, in addition to this thread (although, I found them via this thread. Post 2, again): http://www.overkillrc.com/GT3X-Firmw...lp%20cards.pdf http://www.overkillrc.com/GT3B/GT3B-...NUAL-0.6.1.txt The manual is a little hard to read but once you understand it, programming becomes simple. Last edited by KJ10; 05-02-2013 at 08:41 PM. |
05-02-2013, 09:22 PM | #2785 |
I just got it so its the .6.1 I have been finding random stuff on YouTube and I think I am close to getting what I have to working ok. Got some things to work out so I'll check out the links. Thank you.
05-04-2013, 04:54 PM | #2786 |
Rock Stacker Join Date: Oct 2009 Location: Canada
Anyone have to replace the steering pot on their GT3C? Mine is flakey and was thinking about tearing apart my glitch 3B and swapping the pots but wondering if its not as simple as that. I know I have to account for the power switch which seems to be wired into the little board that is attached to the pot but I can work with that. Just wondering if the 2 pots are similar in spec.
05-04-2013, 04:58 PM | #2787 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
Yes, man. The pot sucks. I've changed or repaired 2 of them already. The GT3C ones. I always take the switch out of there, and move it anyway, because the wires fail on the switch in the steeringwheel. Good idea to get that pot fixed. We thought one of the servos was really messed up, but after switching cars on the same radio it was obvious the TX pot was dead.
05-05-2013, 09:09 PM | #2788 |
Newbie Join Date: Mar 2013 Location: middle
I'm having an issue with my ch 3. Whenever I plug it into the Rx in the ch 3 spot the tx loses the ability to steer and the throttle twitches. Anyone know what I'm doing wrong and can give me a good step by step to setting up my lcc dig with the 3 position trim? Thanks in advance |
05-06-2013, 05:30 AM | #2789 |
Rock Stacker Join Date: Mar 2013 Location: Newfoundland
Hey all just wondering about the firmware versions. Older ones have 3ch,4ch etc. With the new updates like..6.1...what channel is it? It looks like it can be whatever u wasn't if you map the buttons. Any help be appreciated!
05-06-2013, 07:28 AM | #2790 |
Rock Stacker Join Date: Dec 2006 Location: charleston
After hacking the GT3B has anyone had a range issue with theirs I have hacked mine and cannot get more than 10 feet away or it losses all signal, I have put a brand new out of the box receiver on it and same issue, I have a couple buddies that have hacked ones and theres does the same, any help would be apperciated.
05-06-2013, 01:46 PM | #2791 | |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
05-06-2013, 02:25 PM | #2792 | |
Rock Crawler Join Date: Feb 2012 Location: Michigan
| Re: GT3B Hack Question and Answer Thread Quote:
05-06-2013, 05:57 PM | #2793 | |
I believe both firmwares have up to 8 channels. When you set up a new model, you have to tell the TX how many channels you need so you can program them. If you leave it @ 3 channels, you can't program a 4th+ channel in the TX regardless of the RX you use. | |
05-06-2013, 06:00 PM | #2794 |
Ahhh ok I'll have a look and check it out when I get home in a few days. I figured it was something like that. I didn't get into it much, I'm still reading and trying to figure out how to use it in my head hahahaha. Thanks!!!
05-06-2013, 06:51 PM | #2795 |
[QUOTE=Charlie-III;4310973]What are you plugging into channel-3? If a dig servo, maybe the servo is bad. If it's a large (200inoz+) servo, you may be browning out the RX. I'm using the standard LOSI MRC servo. I had it working before I did the hack, I just only had front dig capability. ***edit*** You were right I just checked it with another servo and everything else still works. Now I just need to order a new servo and figure out how to program the ch3. Thanks for the help! Last edited by maquet24; 05-06-2013 at 06:58 PM. |
05-06-2013, 06:59 PM | #2796 | |
[QUOTE=maquet24;4311059] Quote:
As to programming, are you running the 0.4 or 0.6 firmware?? For dig, the basic is: Pick a switch on the TX Set for 3 position Set one way +100, the other way to -100, middle = 0 Some of the programming steps are similar to dual ESC with dig & proportional, you just are not mixing 2 throttle channels. | |
05-07-2013, 02:56 PM | #2797 | |
I have a gt3b and some old am radios I can grab a pot from. Gonna rewire the whole inside of the steering module (power/pot). Ya it sucks. I really want to recommend these radios to my friends since once you flash them they have so many options but I bought the 3B, had throttle pot issues i fought with forever thinking it was my esc/motor combo. Once I found it was the radio I shelved it. Recently bought the 3C and steering pot issues after 3 hours of use. I keep getting the radios built on a monday :P | |
05-07-2013, 09:06 PM | #2798 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
I have 2 rx's and I cant have them both on at the same time, otherwise they both run at the same time. It's there any way I can have both on and only run one? Like have one on a trailer, and the other pulling, both on so I can just switch channels to load the one off of the trailer?
05-08-2013, 05:29 AM | #2799 |
nope, that's the way this system binds to the receivers, unlike the spektrum system that only operates each individual receiver at a specific model memory.
05-08-2013, 02:44 PM | #2800 |
Newbie Join Date: Mar 2013 Location: Redding
| Re: GT3B Hack Question and Answer Thread |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
