04-17-2015, 12:49 PM | #3981 |
Newbie Join Date: Apr 2015 Location: Rochester
| Re: GT3B Hack Question and Answer Thread
Been there done that, talks nothing about performance or AFHDS vs AFHDS2.
04-17-2015, 12:53 PM | #3982 |
| Re: GT3B Hack Question and Answer Thread |
04-17-2015, 01:17 PM | #3983 |
It shows that it comes with the FS-A3 receiver that should operate on 2.4GHz AFHDS2A signal.
04-17-2015, 01:26 PM | #3984 |
The box and description says AFHDS...This isn't a flysky branded tx/rx. Dimension can give this stuff whatever name they want.
04-17-2015, 01:35 PM | #3985 |
Rock Stacker Join Date: Nov 2010 Location: JAPAN
I got a request. Can we stop talking about radio that are not GT3B. With over 200 pages now the thread is getting harder to keep up with. This thread is the only thread I look at when comes to anything about my GT3B. I love and want to thank all the hard work put into the GT3B. Thanks Greg
04-20-2015, 11:19 PM | #3986 |
Pebble Pounder Join Date: Oct 2014 Location: Canada
Just through my order in for a GT3B firmware kit. Then realized I have the GT3C... Will I be able to make it work with some direct soldering or buy using a few header pins I have laying around?
04-20-2015, 11:31 PM | #3987 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
I just hacked mine with a two year old kit. Or I should say my wife did. I was having problems with the links up loading right and asked her to help. I had everything hooked up to my gt3c and computer and went out to the shop, leaving all the directions by the computer. Next thing I know she comes out and says the red light is flashing on the board, you need to do the rest!!!! So yes it will work. |
04-21-2015, 01:16 AM | #3988 | |
| Re: GT3B Hack Question and Answer Thread Quote:
04-21-2015, 12:30 PM | #3989 | |
Do you want me to change your order to a gt3c kit? | |
04-21-2015, 04:58 PM | #3990 | |
Can't PM, the order number is OK-1536 Stoked to unlock these radios and throw some holmes BR minis in the rig Last edited by Savagethrash; 04-21-2015 at 05:00 PM. | |
04-21-2015, 05:30 PM | #3991 | |
04-21-2015, 09:57 PM | #3992 |
04-22-2015, 02:02 PM | #3993 |
04-22-2015, 08:15 PM | #3994 |
Pebble Pounder Join Date: Feb 2013 Location: Canada
I've had my radio for only a month now but it doesn't seem to be working properly to me. I was trying to use the exponential function today however it didn't seem to work properly. It acted more as a trim function rather than exponential. When I adjusted the expo, the vechile would start moving forward without me touching the throttle, or if I adjusted it the other way it would go in reverse as though I were adjusting the sub trim. I don't have this prohlem on my futaba radio. Anyone else have problems with the expo funtion? I wanted to soften my thottle but expo doesn't work.
04-22-2015, 08:46 PM | #3995 |
Pebble Pounder Join Date: May 2014 Location: Williston, ND
Just wanted to post up my thanks to losikid for all his work. I've used your tutorials (and your troubleshooting posts in this thread) to hack 2 radios for myself. Running 6 channels on my scalers. Whenever someone asks where they can get a radio I refer them to overkillrc.com. Don't think anyone has followed through yet though, since I seem to be one of the only RC guys here locally that is really interested in the electronics part of RC.
04-22-2015, 08:59 PM | #3996 | |
Make sure your radio is calibrated (turn steering wheel max clockwise then enter-LONG to enter the calibration menu) Also, are you using any trim? | |
04-23-2015, 08:51 AM | #3997 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
finally hacked mine. 3ch doesnt work at all. any idea why? reading is this very long thread. i never Calibrated the radio after I hacked it. going to start there Last edited by m1009cucv; 04-23-2015 at 09:15 AM. |
04-23-2015, 05:04 PM | #3998 |
04-24-2015, 12:25 PM | #3999 |
I kinda suck with electronics. Whats that mean in English haha
04-24-2015, 01:15 PM | #4000 |
Its the heart and soul of utilizing all the channels on the GT3B/GT3C Directly from the manual Code: - Key mapping specific for each model: > choose menu REV and press ENTER-long > menu REV will blink > choose trims (id: 1 2 3 d) or other keys (CH3: C, Back: b, End: E) or if trim is OFF, then also trim keys (id 1 2 3 d with left/right arrow) > press ENTER and modify first setting > press ENTER and modify next setting > .... ----- steps of settings of trims (1 2 3 and D/R): - sequence: function -> buttons -> step -> reverse -> opposite_reset -> previous_val -> rotate - function: selected function listed at the end of manual - B buttons: MO - momentary, hold left/right trim key to get end values, when nothing pressed, servo is at center NL - no long keys, long press is the same as short press AR - autorepeat is on RS - long press of one of trim keys will reset to centre/reset value EN - long press of trim key will set to coresponding end value - step: select trim step for one trim key press (1, 2, ... 100, 200), not available when buttons MO or fuction is list of items (multi-position) is identified by symbol "V" - RE reverse: 0 - no change 1 - swap left/right trim keys - OR opposite_reset: not available when buttons MO 0 - no change 1 - when trim key is pressed and value is at opposite side of center/reset, set value to centre/reset, - PV previous_val: available only when buttons MO or fuction is list of items (multi-position) 0 - no change 1 - instead of setting value to centre/reset when key is released, it is set to previous value, which was active before key press - RO rotate: available only if fuction is list of items (multi-position) 0 - no rotate 1 - rotate from max item to first item and back ----- steps of setting of keys (C b E 1< 1> 2< 2> 3< 3> d< d>): - sequence: function -> momentary -> reverse -> prev_val -> function_long -> reverse_long -> prev_val_long - function: selected function listed at the end of manual - MO momentary: only available for 2-state functions (channel, ...) 0 - switch, key press will switch something (channel value, ...) 1 - momentary, value change will be active only while key is pressed - RE reverse: only available for 2-state functions 0 - normal, no-press or default value is left endpoint 1 - reverse, no-press or default value is right endpoint - PV prev_val: only available for 2-state functions 0 - key release or OFF state sets value to left endpoint (noREV) 1 - key release or OFF state sets value to value active before key press or ON state - function_long: function applied when long press of key happens, choose from the same list as function, identified by "V" symbol - reverse_long: same as "reverse" + "V" symbol - prev_val_long: same as "prev_val" + "V" symbol ----- Functions assignable to trims: ============================== OFF - nothing, it is possible to assign each button individualy as key TR1, TR2 - trim of channel 1/2 DRS, DRF, DRB - dualrate of steering/forward/back EXS, EXF, EXB - expo of steering/forward/back CHn - change channel "n" value in range -100...100 STn - subtrim of channel "n" SST - steering speed turn 1...100% SSR - steering speed return 1...100% CSn - channel speed for channel "n" 1...100% 4WS - 4 wheel steering mix -100...100% DIG - DIG throttle mix -100...100% MP1 - Multi-Position 1, switches position up/down MP2 - Multi-Position 2, switches position up/down MP3 - Multi-Position 3, switches position up/down MP4 - Multi-Position 4, switches position up/down Functions assignable to keys: ============================= OFF - nothing CHn - switch channel "n" value from one end value to opposite end value. There is special handling for CH3 button. When using 3-position switch instead of CH3 button and momentary is selected for this button, then centre 3-pos value will also be detected and set to servo (use 1K resistor to GND to get middle state) CnR - reset value of channel "n" to centre 4WS - switch crab (CRB) no-crab (NOC) for 4 wheel steering DIG - switch DIG mix between -100 and 100 (more useable when using return to previous val key setting) DGR - reset DIG mix to centre MP1 - Multi-Position 1, switches position up (at END back to 1.) MR1 - Multi-Position 1 Reset, switches position to first one MP2 - Multi-Position 2, switches position up (at END back to 1.) MR2 - Multi-Position 2 Reset, switches position to first one MP3 - Multi-Position 3, switches position up (at END back to 1.) MR3 - Multi-Position 3 Reset, switches position to first one MP4 - Multi-Position 4, switches position up (at END back to 1.) MR4 - Multi-Position 4 Reset, switches position to first one T1S - start/pause timer1 T1R - stop + reset timer1 T2S - start/pause timer2 T2R - stop + reset timer2 BRK - switch on full brake, this overrides throttle position BLS - battery low shutup, stop beeping, predefined to END-long Also take a look at this link http://overkillrc.com/GT3X-Firmware/...lp%20cards.pdf |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
