04-04-2015, 05:45 AM | #3961 |
Pebble Pounder Join Date: Feb 2013 Location: Canada
| Re: GT3B Hack Question and Answer Thread
My radio came with a enter button that would not get a response when pushed. I figured since it was a momentary push button and that it would work if pushed just right, the circuit was not being completed. So I used a small flat to pry the cover of the switch off, which holds the pink button which pushes against a small metal tab which then flexs and touches the switch contacts completing the circuit. The metal plate in mine seem flat and so when I pushed the button, it did not flex and touch the contacts. So I took my small flat and tried to bend the two sides down and middle up on the metal tab. I reassembled the switch and it works perfectly now. I'm going to guess since Rockhugger your switch was working and now does not, that this your problem because the switch is soldered right to the board so nothing else could have come loose causing this. Just a guess. I'm anything but a electronics wizard. Hope this helps. Last edited by Sapes; 04-04-2015 at 05:48 AM. |
04-04-2015, 11:00 AM | #3962 | |||
RCC Addict Join Date: Oct 2006 Location: crawlifornia
| Re: GT3B Hack Question and Answer Thread Quote:
My friend and I took the switch a apart last night and were able to get it to respond again. It lost a little of the tactile "pop", perhaps from reassembly not being perfect, but it's functioning properly and I'm able to get into "long enter" modes now. Than you Quote:
Thank you for the responses fellas. Quote:
My switch was working perfect upon arrival, it only flubbed after about a week or so of intermittent use in trying to program function for an hour here and there after work. Sapes post fixes it, and although ours lost a little of the tactile click after repair, it now functions properly. Yes, the tactile "click" was working the same before (responding) and after (not responding). It's like it just stopped making the electrical bridge. I literally was having to push and massage the button and sometimes it would respond, and long enter was a PIA. I was ready to solder in a new switch. Thank you | |||
04-04-2015, 07:55 PM | #3963 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
That must be on the gt3c...... Ain't got none of them in my 3b lol
04-08-2015, 10:25 AM | #3964 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
hey losikid, how much would you sell a hacked gt3b contoller and reciver for? and will it work for a 2 speed transmission from rc4wd? Thanks jacob |
04-08-2015, 04:44 PM | #3965 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
Does anybody know where to find a trigger for the gt3b? Mine broke and I can't find one on eBay :(
04-09-2015, 12:32 PM | #3966 |
Newbie Join Date: Apr 2015 Location: Clifton
I see the 4-pin header and ball bearing for the GT3B mod are out of stock on overkillrc.com. Does anyone have a part number or know what size they are so that I can get them from somewhere else?
04-09-2015, 02:51 PM | #3967 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
I had a similar Enter button issue on my C. I simply gave it a tiny drop of WD40 then worked it for a few minutes until the click sounded right then used that canned air to clear it out and so far its been perfect.
04-09-2015, 07:21 PM | #3968 |
| Re: GT3B Hack Question and Answer Thread |
04-09-2015, 07:34 PM | #3969 |
04-10-2015, 08:40 AM | #3970 |
Gosh why do they use that's same green the Gt3c was in? Donno I think its an ugly color.
04-15-2015, 03:56 PM | #3971 | |
| Re: GT3B Hack Question and Answer Thread Quote: ~ there isn't a silicone grip ~ The the little bits hiding the screws on top are now hard plastic instead of soft rubber. They weren't fun to get out ~ Some other little things ~ And worst of all, its not even close to compatiable with the current firmware. Completely different un branded cpu. So no hacking it...and the cpu is unbranded so i don't even know where to start to try and write a new firmware for it :( | |
04-15-2015, 03:58 PM | #3972 |
However, it may turn into a guinea pig for future projects/plans I have. I just wish it had one lcd size up, then it's fate would have been certain
04-15-2015, 03:59 PM | #3973 |
I want page 200
04-15-2015, 03:59 PM | #3974 |
I want page 200 bump
04-15-2015, 03:59 PM | #3975 |
to page 200
04-15-2015, 03:59 PM | #3976 |
I got page 200
04-15-2015, 03:59 PM | #3977 |
Saved for future. I plan on doing an updated list of links/help stuff in this post. |
04-15-2015, 04:01 PM | #3978 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
Lol
04-17-2015, 12:35 PM | #3979 |
Newbie Join Date: Apr 2015 Location: Rochester
I just ordered one of these Dimension GT3X, performance-wise an upgrade from a GT3B or GT3C? I cant seem to find any info on the difference or benefit from going AFHDS to AFHDS2?
04-17-2015, 12:40 PM | #3980 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
