![]() | #1161 |
Quarry Creeper ![]() Join Date: Nov 2006 Location: out in boonies!!
Well just did the screen mod, I like it a lot better now!!
![]() | #1162 |
Quarry Creeper Join Date: Feb 2012 Location: SAN DIEGO
It's Sic Huh? Good job. wait till you SEE it in the daylight : ) |
![]() | #1163 |
Rock Stacker Join Date: Oct 2009 Location: Canada
Awesome thread guys. Info galore. Thx losikid for organizing it all. Question. I just got my programming card and seems the fates have removed the pics that were in the programming instructions found on the net. Anyone know a website that still has them active? Losikid I swear I read somewhere that you were changing hosts or something and gave tips on how to find stuff on your site while your doing your move. Cant find that post now though. Thanks for any help. |
![]() | #1164 |
![]() | #1165 |
| ![]() I'd love to replace the channel 3 button with a pot. I have it setup now to do dig like your instructions do, but would prefer a knob to turn left/right to change bias of dig.
![]() | #1166 |
![]() | #1167 | |
| ![]() Quote:
5k...although 10k would work too. Resistance isn't a huge issue because all the pot does is form a potential divider to vary the output voltage from 0volts to 5volts...this output voltage is then read by the A/D converters to create a 8 bit digtal output (1024 steps (what you see in the calibration menu)) After installing the pot you'll need to calibrate it through the calibration menu (turn wheel full clockwise, and press enter (might be enter-LONG)) As for pot install....find a 5volt and 0volt line (splicing into the throttle is probabaly the easiest). Then find the circuit that is connecting the ch3 button to the microchip, and use that as your center wire. | |
![]() | #1168 |
Newbie Join Date: Feb 2012 Location: Russia
Hello to all! Please, help me! I have This Radio-control system and STM8S-Discovery programmer. My radio now have 4-pin adapter and it connect to prog. But when i try to read my old firmware from radio in STPV it say Error : Cannot communicate with the tool. Wrong tool selection or check tool power supply or check that a previous session is closed. PS my programmer is broken in two. Can anybody help me? |
![]() | #1169 |
Quarry Creeper Join Date: Sep 2011 Location: Spring Texas
Hi guys, how to order more than one RC on the website? --- I am here: http://maps.google.com/maps?ll=29.988239,-95.332202 |
![]() | #1170 |
You know what guys, there is customer service and There is Losikid.....you ask something and immediatly he answer and modify the website...Congrats and tks --- I am here: http://maps.google.com/maps?ll=30.078760,-95.460168 |
![]() | #1171 |
Pebble Pounder Join Date: Oct 2011 Location: Exeter Ontario
Losikid.... You download links for firmware are not updated with the new .webs.com link so I can't download. Any tips. I can open the script in my browser but can't save as .s19 file.
![]() | #1172 |
| ![]() You should have a email from me with download links of the firmware...i'd use those as they are not hosted thru my website
![]() | #1173 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
reverse cogging? i put the 3 channel rx in my MRC, all stock electronics, set endpoints, and trims. nothing else, throttle is smooth forward but cogs terribly through the whole range of throttle in reverse. steering is smooth. did not do this with original losi tx/rx where do i need to start making adjustments? i didn not put the rx antenna up through the straw, just laid it along the battery tray. |
![]() | #1174 |
Anybody knows what is Error mean: Error : Cannot communicate with the tool. Wrong tool selection or check tool power supply or check that a previous session is closed. |
![]() | #1175 | |
Pebble Pounder Join Date: Oct 2008 Location: Downieville
| ![]() Quote:
![]() | #1176 |
yep, that was a homer simpson moment there..... thanks.
![]() | #1177 |
So, I'm programmed for dig. When you push the switch for front/rear dig, is the opposing wheel (that's supposed to be locked) supposed to rotate forward ever so slightly? It's almost like the trim is wrong, but only when dig is enabled. Next, when you have it proportional front/rear if you set it to anything other than 0 it only goes forward. Is reverse supposed to work proportionally? Say I have it set to -20 (so the back is going slower) I can go forward just fine, but reverse only makes the front wheels go reverse. The rears are locked or going 20% slower forward than the fronts. |
![]() | #1178 | |
| ![]() Quote:
How much slop is in your drivetrain?? Any slop in the hex/wheel connection, CVD/dogbone joint, axle shaft to diff, gear to gear, pinion to spur, etc. will ALL translate to wheel movement whether the motor is locked or not. Is this what you are seeing, or something else? | |
![]() | #1179 | |
| ![]() Quote:
![]() | #1180 | |
| ![]() Quote:
I do have the same exact program on them (used my Castle Link to upload the same program to each). I have the Sidewinder set to crawler reverse and drag brake of 213%. I'll just calibrate them both again in the morning and see how it goes. | |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
