06-17-2012, 11:28 PM | #221 |
| Re: Machinists Corner
I got one of each. I need to pick up the 6" for the quill.
06-18-2012, 08:02 AM | #222 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
They come in 6", 12", 24" and 36" and can be cut to any size needed and all 3 can be had for around $110.00.
06-18-2012, 08:10 AM | #223 |
Also 24".
06-18-2012, 09:11 AM | #224 |
| Re: Machinists Corner |
06-19-2012, 04:11 PM | #225 |
So I've been playing around off and on for a few days now and noticed that they Y axis moves considerably easier than the X axis. No, the gib locks aren't on. Is this a normal thing? I would assume that it would be to a point considering its length. Both are lubed up pretty good, think it might be a bit stiff from sitting? |
06-19-2012, 05:11 PM | #226 | |
There should be gib adjustments, usually they are set screws with locknuts. It should have 1 gib lock but I would guess at least 4 adjusters.. Grab your table and watch your DRO's, you may get .001" maybe from movement. On mine they are on the back side under the carriage. Quote:
06-23-2012, 12:15 PM | #227 |
Quarry Creeper Join Date: Jan 2009 Location: Estonia
Hey Duuuuuuuude. I would like to see how can you mount the DRO displays. I'm a machinist myself, but didn't get a good picture on how the screen could be mounted. Could you tell us or post a pic if you already mounted them. Thanks |
06-23-2012, 12:17 PM | #228 |
The displays have magnetic mounts on the back of them so they can be attached to the machine anywhere there is a flat metal surface.
06-23-2012, 01:05 PM | #229 |
Right now they're just stuck to the side. I've got a swivel mount in mind, just have to make one.
06-23-2012, 01:31 PM | #230 |
And there is just one wire between the display and dro unit? I've been looking for those DRO units, but all I could ever find was industrial and pretty expensive. Thanks for this info. |
06-23-2012, 01:50 PM | #231 |
Yup, just one 4' wire. It can unplug from the display...never looked to see if maybe it was a mini usb or something that you could find an extension for...
06-23-2012, 03:48 PM | #232 |
MFDesigns Join Date: Feb 2009 Location: ValleHOE
nice machine dude, i just got a grizzly g0619 and am loving it. i noticed alot of slop in the lead screw and have tryed to adjust it out but it keeps coming back, oh well, maybe i need to do a dro like you did. where can i get something like that? weel the reason i poped in here is to find out what RPM to run a touchoff tool at? thanks in advance. mike |
06-23-2012, 10:44 PM | #233 |
Newbie Join Date: Nov 2010 Location: Canada
If the tool your referring to is an "Edge Finder" I usually run them at 800-1000 RPM
06-23-2012, 10:57 PM | #234 |
Hooray! I finally got to do something fun instead of stuff I had to do. A mathmatical error put a couple of the holes in the wrong spot, but they aren't off by much. Next to the one I cut a month or so ago on the drill press. |
06-24-2012, 03:45 AM | #235 |
06-24-2012, 07:04 AM | #236 |
Look at ya go, "Eyeball Enginering" , I wear out my calculator while I'm making stuff, this is definately where "measure twice , cut once" comes into play . Last edited by CREEPERBOB; 06-24-2012 at 09:42 AM. |
06-24-2012, 09:32 AM | #237 | |
Quarry Creeper Join Date: Jul 2008 Location: Splendora
| Re: Machinists Corner Quote:
06-27-2012, 10:53 AM | #238 |
Quarry Creeper Join Date: Apr 2009 Location: KC
Has anyone in here had any dealings with HAS equipment?... mainly their lathes.
06-27-2012, 11:47 AM | #239 |
06-27-2012, 01:37 PM | #240 |
RCC Addict Join Date: May 2010 Location: Midwest
Agreed. HAAS equipment in my opinion, is some qaulity machinery. I mainly deal with Okuma now but, started off many years back using HAAS CNC machines.
Machinists Corner - Similar Threads | ||||
you Machinists can probly appreciate this... | STANG KILLA SS | Tools, and Procedures | 41 | 05-14-2011 12:59 AM |
Machinists..... | mrpink | Chit Chat | 1 | 08-30-2010 08:31 PM |
Question for the machinists out there... | scally6 | Chit Chat | 12 | 12-03-2009 08:25 PM |
Machinists...opinions? | JasonInAugusta | Tools, and Procedures | 5 | 07-23-2007 11:00 PM |
