Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: 3d printer for rc parts
Old 06-17-2018, 08:45 PM   #561
Default Re: 3d printer for rc parts
Switched to a hollow 20x20x20 mm cube that is hollow and has a single wall. Faster printing, less filament and I can watch it better. I printed the one on the left using the same settings as I have been using for the XYZ cube except for t it being hollow and single wall. The one one the right was printed using spiral. Night and day difference.
Watching it print it appears to me that the blob is being created at the end. According to S3D this is fixed with a coasting setting which Slic3r PE doesn't have. I'm going to print the next one with the seam position set to Near instead of Random and see what happens.
Gramps is offline   Reply With Quote
Old 06-17-2018, 08:48 PM   #562
Finally the hollow cube to print decent. I'll now try the XYZ cube tomorrow and see if I get the same results. What ended up working was to set Seams: Near in Slic3r PE
Old 06-18-2018, 03:24 PM   #563
Default Wanhao all metal hot end
Anyone have any experience with this all metal hot end? It's like half the price of a Microswiss.
https://www.amazon.com/Metal-Hotend-...tag=tv-auto-20
Old 06-19-2018, 12:44 PM   #564
I'm having an issue with the Inland PETG filament, it has happened several times that it will quit extruding, normally this is at the beginning of a print during the skirt. Thought maybe I was leaving it heated in the hot end to long. Today I loaded the filament, heated the bed to 90c when it reached about 80-85c I preheated the hot end to 240c. When it reached temp I pressed print on Octoprint. When it went to do the skirt it was extruding any filament. Pressed the release lever and pushed it down into the hot end and it finished the skirt and proceeded to print.
Do I have some bad filament or is there something else I should be looking at?
Old 06-19-2018, 01:28 PM   #565
I use a command line in gcode that pushes 10mm and then wipes before actually printing.
Is filament dripping as it’s preheating ?
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 06-19-2018, 01:48 PM   #566
With PLA it would drip during preheat, with the Inland not so much.
Old 06-20-2018, 02:06 PM   #567
Try extruding manually with the printer control in Octoprint to see if the filament just needs more priming than with PLA.
If not:
1) Also check to see if the extruder is grinding the filament. If you have grinding try increasing the hot end temperature 5 degrees and try again.
2) Check the extruder idler tension. Too loose?
3) Verify that the filament is round and is consistently in spec over a few meters.
k7zpj is offline   Reply With Quote
Old 06-20-2018, 02:14 PM   #568
Default Re: Wanhao all metal hot end
Another option is to upgrade to an e3d Titan Aero extruder. It would take your printer to the next level. https://www.thingiverse.com/thing:2178694
Old 06-20-2018, 03:50 PM   #569
Went ahead and ordered one, it came today and it looks just like the Micro Swish and the directions on the back of the bag are to micro-swiss.com
Comes in a single bag instead of individual bags like a Micro Swiss. Haven't installed it yet so no comment on how it works.
Old 06-20-2018, 05:35 PM   #570
So, I read these types of threads because even though I can do the 3D modeling and make a part on a "production" 3D printer, I have absolutely no experience in doing, or fully understanding, the upgrades that people do. What exactly does this upgraded nozzle do and does it require any tweaks to the printers firmware/software?
BigSki is offline   Reply With Quote
Old 06-20-2018, 07:35 PM   #571
The all metal hotend eliminates heat caused problems as there is no PTFE tube to melt and jam the filament. I’ve also seen much more even heating, and less heat bounce at temp(with proper PID) I use it for printing PETG, at 235/240
Hang up and Drive
Old 06-22-2018, 05:55 AM   #572
All metal throats are recomendable almost for every high temperature material.
But if you are going to print only on standard PLA then it is better to use throats with PTFE tube.
PTFE tube in the throat actually avoids jamming of the PLA when it softens going down the throat to the hotend.
gonper is offline   Reply With Quote
Old 06-22-2018, 06:17 AM   #573
I've had issues with an all metal throat when using PLA. They would always jam after a few hrs of printing.
whitrzac is offline   Reply With Quote
Old 06-22-2018, 10:02 AM   #574
Yashua
CREEPERBOB's Avatar
I have the e3d hotend that I haven't put on yet because I'm going to be using some tpe pretty soon and it won't work well with the Bowden setup.
I decided so we are building on it today.to give my second printer to 2 of my grandsons
CREEPERBOB is offline   Reply With Quote
Old 06-22-2018, 05:08 PM   #575
Anyone print with POM/delrin? Bought a small roll to play with, I may just hook the bed up to an esc and monitor the temps manually for the first few layers, lol.
Old 06-22-2018, 08:42 PM   #576
Custom Carbon Fiber
Robbob's Avatar
Ive been eyeballing it, interested to hear what you find on it.
Robbob is offline   Reply With Quote
Old 06-25-2018, 05:24 AM   #577
Initial results were what I expected...
Need to get the bed a lot hotter than the stock board will allow. Survey says between 120-160c. Ordered a mosfet kit and trying to track down a 24v supply for just the bed.
Old 06-25-2018, 07:31 AM   #578
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
What surface are you printing on whiz? Try a layer of 3m blue tape, I bet it sticks without needing to upgrade your machine.
JohnRobHolmes is offline   Reply With Quote
Old 06-25-2018, 07:33 AM   #579
I’ll be doing a presentation today at a grade school. First, we will burn some wood. Then, I will design and 3d print something in front of them. Should be fun!
Old 06-25-2018, 09:35 AM   #580
Custom Carbon Fiber
Robbob's Avatar
Bed adhesion was a big thing I read about with delrin and warping.
What extruder temp?
I read most guys running in the 100* bed temp area and using blue tape with either hairspray or the alcohol rub.
The warping got me to wondering though if a slow cool would be better. Enclose the printer to cut the outside air down and run the fan slower. Warping from my understanding is from cooling, too fast the material shrinks. So if this was cooled slower maybe it wouldnt?
Kind of like PETG fan settings are lower (at least for me) then normal PLA.
3d printer for rc parts - Similar Threads
Can your printer do this? CREEPERBOB Chit Chat 19 10-14-2011 07:33 PM
Are you a printer in OH or know someone who is? Phatmac Ohio 5 02-20-2009 02:14 PM
