07-02-2018, 06:20 PM | #621 | |
| Re: 3d printer for rc parts Quote:
07-02-2018, 07:44 PM | #622 |
Rock Crawler Join Date: Nov 2014 Location: Dells
| Re: 3d printer for rc parts |
07-02-2018, 08:20 PM | #623 | |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
less money and time to throw at materials and a printer. I just double check my measurments and part design before I let shapeways fire the laser. | |
07-02-2018, 08:27 PM | #624 | |
Try printing on 28lb paper or craft paper coated with Elmers glue (Let dry before printing). Delrin likes sticking to fibers. Modifying the firmware is hard due to the MP select mini not being open source. The only ones I have seen running custom firmware had the controller replaced with a RAMPs board or a mini-Rambo. | |
07-03-2018, 09:23 AM | #625 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: 3d printer for rc parts Unless the mini uses substantially smaller springs, it should work fine. If not it's simple to size it up or down until it fits, or just redesign one from scratch. That spring cup is so simple that it shouldn't take more than 5 minutes to design in your 3D CAD program of choice.
07-03-2018, 10:16 AM | #626 | |
Why use any program but the slicer? 1 % or 2% scale up should solve fit issues Hang up and Drive | |
07-03-2018, 11:36 AM | #627 |
| Re: 3d printer for rc parts if the spring is different, my guess is that it would be smaller on the Mini, not larger, and I'm sure you'll have to scale it down more than 1-2%, but yes, if the same design will work, scaling it is the easiest option. What I was attempting to say last time was that if simple scaling won't work for whatever reason, it's still only a 5 minute job to design one from scratch in CAD.
07-03-2018, 12:14 PM | #628 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
It is a shame you have this experience. My printer is literally adjust, slice and print. No mess to fuss and hardly any misprints after the first layer(most are induced by failure to prep) I do however wish I could design well enough to have your confidence. | |
07-03-2018, 01:38 PM | #629 |
| Re: 3d printer for rc parts Shapeways is probably fine if you're just printing crap from Thingiverse or making very small, simple widgets, but if you're doing any of your own design work, the cost and wait time from Shapeways will bury you. The bulkhead that I did for my Clone Hammers would probably cost $70-80 each, and I went through some 20-odd prints while I was tweaking the design. If I had to spend $80 and wait 2 weeks for each of those, it would take me 9 months and cost me $1600 to develop a part for a $130 car. |
07-03-2018, 02:56 PM | #630 |
it took me literally 5 minutes with some calipers, 30 minutes of cad fiddling, and 1 print for a 15$ dollar to me part from shapeways. fit and finish is perfect. no breakage. remember that measure twice cut once saying in woodworking? apply that to printing. going through shapeways is a non issue if your design is mathematically correct. I assure you. ive printed plenty through shapeways. ive never had an issue. size the parts right and you are golden. |
07-03-2018, 10:02 PM | #631 |
For simple widgets, sure. When your designs get more complicated, that's just not practical. This took 20+ prints to get perfect, and would cost around $75 each from Shapeways. |
07-03-2018, 10:16 PM | #632 |
Measure measure measure. Cant stress it enough... All of my stuff is usually first print. I decided to slim down the tcases to cut on cost. Sent from my LGMP260 using Tapatalk |
07-03-2018, 10:23 PM | #633 |
If you can measure a bulkhead with 6 mounting points on 3 planes that also locates the shock towers, body mounts, adjustable battery tray and custom bell cranks and enough support bracing to keep it strong with enough precision to get it right the first time, then you're one hell of a talent.
07-03-2018, 10:33 PM | #634 | |
Im pretty good with cad. Its not hard. Taking things from paper to computer isnt hard. Quote:
07-04-2018, 09:44 AM | #635 |
| Re: 3d printer for rc parts Happy 4th of July !!!! (Tricolor print sliced on Cura 3.4, printed on Lulzbot TAZ 5) |
07-04-2018, 10:31 AM | #636 |
| Re: 3d printer for rc parts You're completely missing my point. Your designs are very simplistic and can be designed and printed with a high degree of confidence. You can't do that with more complex designs no matter how smart you think you are.
07-04-2018, 12:56 PM | #637 | |
Must be dense if you cant turn 2d into 3d. Cad is not hard. Period. If you dont get it you dont get it. Sent from my LGMP260 using Tapatalk | |
07-04-2018, 02:00 PM | #638 | |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
Taking measurements are one thing, getting the actual physical part installed and realizing you'd like to adjust a few things is how a lot of us "dense" people work things out. Also, why are you even in here ragging on others if you run everything through shapeways? Last I looked this was 3D Printer thread... Sent from my SM-G930V using Tapatalk | |
07-04-2018, 02:33 PM | #639 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
On a little lighter side, does it make sense to print this item this way? The Note in the read.me file says "Notes: prints standing on its side so no support needed depending on material on your printer, I use ABS, so I printed with support for the one with places made for furniture tabs to get ite perfekt in size" To me it makes more sense to print it laying on it's back with the legs up. I did start it that way and it printed strange, You would think that it would lay down the 60x65mm outline then fill it but it didn't it put a rectangle at each end filled them but not in a conventional pattern. Then just` running parallel lines between the 2 end boxes. Wasn't sticking good and I didn't like the way it was going to I cancelled. Currently printing as per instructions on it's side but I don't see how this is going to happen with no supports. |
07-04-2018, 02:56 PM | #640 | |
You can bridge but you can't cantilever with a 3D printer in normal earth gravity. For Slic3r PE. In Print settings > Layers and perimeters > Advanced section, do you have External Perimeters First checked ? Also check that the infill type isn't rectilinear. You may want to upgrade Slic3r PE to 1.40.1 beta. It seemed a little more stable that 1.40.0 Last edited by k7zpj; 07-04-2018 at 02:58 PM. | |
3d printer for rc parts - Similar Threads | ||||
Can your printer do this? | CREEPERBOB | Chit Chat | 19 | 10-14-2011 07:33 PM |
Are you a printer in OH or know someone who is? | Phatmac | Ohio | 5 | 02-20-2009 02:14 PM |
