Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: Yeti.Stealths Ascenders
Old 10-06-2017, 03:18 PM   #221
Default Re: Yeti.Stealths Ascenders
Nothing special done to the tyres, got a bit of weight in the wheels and have Crawler Innovations dueces wild foams in them. I believe they work better with the stiffer foams, and I like to slow crawl, let it sit there wheel spinning dead slow and steer around until they bight into something, usually works.
Yeti.stealth is offline   Reply With Quote
Old 10-18-2017, 03:50 AM   #222
I learnt something about crawler tyres today, my new Iroks really sucked, I mean really really bad! Nil grip at my favourite crawl spot, absolutely hopeless and not a chance in hell of making any of my tough lines I use for test and tune sessions.
Installed CI DW rock beast foams because I like em and kept at it, today after god knows how many packs these Iroks started to "switch on" and grip up! There not there yet and cannot make all of my hard lines but there getting close, difference is night and day from when they were new to now.
Still haven't given them a wash in simple green yet.
New Irok = hopeless
Starting to wear in = heaps better
Old 10-18-2017, 04:51 AM   #223
That's like my vaterra tsl's. I still run my original set from September 2015 and I haven't found a tire yet that'll pull lines better than they do broken in. Or noticeably better that is. I'm trying new tires just to make things interesting. It's hard to give them a good break in when I've got so little time to actually wheel so I end up going back to my trusty tsl's when I'm out with friends so my truck doesn't suck on the climbs.
Ben
Itali83 is offline   Reply With Quote
Old 10-18-2017, 11:38 AM   #224
Moderator
JatoTheRipper's Avatar
I've always like the Iroks in the X2SS compound. They hooked up nicely, but they wore way too quickly. Are yours X2 SS?
After Iroks I tried ProLine TSL Super Swampers and never looked back. More grip and more durability with a slight hit on scale factor.
What beadlock wheels are in the photos above?
Old 10-18-2017, 04:47 PM   #225
Yes the Iroks are X2 SS compound.
The wheels are from eBay and are Alientac / GDS racing, 25 mm wide I think. The tyres rub a little on the steering link with the hubs that are supplied with the wheels, so I have ordered the next wider offset hubs from GDS racing, the hubs are not the same bolt pattern as my other eBay wheels.
Old 10-18-2017, 05:55 PM   #226
Natedog's Avatar
Ben
X2, ime the RC4WD Irok looks great, but Vaterra TSL lasts longer and grips better.
Good to know, so what pattern are the hubs? I like my wheel hubs to interchange as much as possible.
Old 10-18-2017, 06:13 PM   #227
Compared to my black wheels, the holes are about 1mm further out from the centre. There the only 2 sets of beadlocks I own so I don't know which ones are "SLW hub" compatable, maybe neither, that's why I went for the proper GDS hubs so I know they will fit.
Old 10-18-2017, 10:35 PM   #228
Also suffered some damage today, broke the rear upper link to axle screw, it's happened 3 times to me now and I have never successfully got the broken bit out of the axle housing without destroying it. This is my prized Codyboy weighted axle too. I have been tinkering around with some ideas to toughen it up.....
I see lotsa people running the alloy upper link riser, but I would think it would put even more load on the 2 screws? I'm not running 3s or a big motor, stock RTR everything, even got the slipper backed off a little.
Attachment 357178
Hey trick on keeping upper link bracket from breaking is to use to zip ties on either side (around input, cross over and around!)
How I fixed this issue u know bankrupt mods
Ascenderbender is offline   Reply With Quote
Old 10-19-2017, 03:33 AM   #229
Cable ties! Why didn't I think of that...
Great idea bender, and a good field repair too.
Old 10-19-2017, 03:43 AM   #230
Nice k10 is it wider than stock?
Old 10-19-2017, 12:49 PM   #231
It's lowered, so maybe that makes it look wider, and the alloy beadlocks are a little wider, that's all.
Old 10-20-2017, 07:19 PM   #232
i think you deserve the title of ''most worn tyres'' or ''destroyer of tyres''
rs10man is offline   Reply With Quote
Old 10-22-2017, 12:03 AM   #233
COMP DAY! and a chance to break these Irok tyres in some more, they are getting better!
We had a cracker of a day, almost 20 scale rigs of all kinds, everyone buzzing about the next upcoming RC4WD Australian Challenge too.
Old 10-22-2017, 12:12 AM   #234
A few pics of some other trucks from today, sorry no pics of my Ascender, too busy puttin' a hurtin' on my new Iroks to stop and take pics!
Old 10-22-2017, 01:23 PM   #235
Where is this located?
Old 10-22-2017, 04:40 PM   #236
Near Newcastle NSW. Are you nearby Bender? Come crawl with us!
Old 10-24-2017, 10:53 AM   #237
Natedog's Avatar
Nice comp/gtg pics as usual, thanks!
Old 11-01-2017, 04:15 PM   #238
No problem Nate, I'm happy to report on all things scale crawling around here for everyone's enjoyment.
Wider hubs turned up, get good clearance now between tyre and steering links.
All prepped for next RC4WD Aussie Challenge, this one will be a 2 dayer with a social night run too!
Don't think I will use the Iroks at the challenge, going to stick with my old Scorpios, they are still out performing the Iroks, don't think the few extra scale points will offset winching up things I can usually drive up. Next time maybe.
NName:  IMG_3774.jpg
Got stance? Or something whatever the kids say these days haha...
Old 11-11-2017, 02:15 AM   #239
I better give the Bronco some attention.
https://www.youtube.com/watch?v=odAr6Mk62G0
Old 11-11-2017, 12:43 PM   #240
K10 with Irok tyres this time.
https://youtu.be/5at_OKNCius
Yeti.Stealths Ascenders - Similar Threads
Life of one YETI - Tom Frajer's Axial Yeti build log TomFrajer Axial Yeti 320 05-22-2017 09:01 PM
Comp classes for ascenders? Biomedchad Vaterra Ascender 15 04-15-2016 02:19 PM
