12-24-2011, 11:37 AM | #141 |
| Re: Szczerba's FF-SZ
Part number for the pede shafts? They don't split/bust driveshaft "ears" like the axials? Or they a different setup? I think the JunFac shaft will work with grease. I might have to trim the "cups" of the junfac's a little. |
12-24-2011, 11:43 AM | #142 | |
| Re: Szczerba's FF-SZ Quote:
google much? link (don't order from barnes and noble ) They require the use of the driveshaft ring, but those alwasy seem to wiggle loose for me. Otherwise they will split just like the Axial ones. Different situation, but the YJ runs pede shafts with the shaft rings and the yokes still manage to bust out. | |
12-24-2011, 11:44 AM | #143 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
Why not try Jason's method for maxx shafts? Drill the maxx yoke out to 11mm and press a pede yoke into it. That gives you 2 set screws and the longest possible shaft length. *edit for link* Maxx Shafts made easy. Last edited by Almighty Malach; 12-24-2011 at 11:49 AM. |
12-24-2011, 11:53 AM | #144 | ||
The front driveshaft needs to be about 55mm. .................................................. .................................................. ............................................. Here's the video, since a new page is started. Broke before run was finished. .... Last edited by Szczerba; 12-26-2011 at 11:25 PM. | ||
12-24-2011, 03:17 PM | #145 | |
# 1953 TowerHobbies.com | 1953 Traxxas Long Truck 1/2 Shaft Pro Pak (6) Madman! | |
12-24-2011, 03:48 PM | #146 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
Just and ideal. MIP X-Duty for the front of a Slash 4x4 w/ a 5mm and 6mm drive hub. The length looks like it would work. TowerHobbies.com | 10135 MIP X-Duty Female Spline Bone Slash/4x4 TowerHobbies.com | 10134 MIP X-Duty Male Spline Bone Slash/4x4 TowerHobbies.com | 08137 MIP Drive Hub 6mm E-Revo/Maxx |
12-24-2011, 04:52 PM | #147 | ||
12-27-2011, 05:59 PM | #148 |
I've been running Pede shafts for years with no complaints or problems, super light to. |
12-27-2011, 06:42 PM | #149 | |
I think I setup these lines up correct. Setup as of right now, the front has alot of anti-squat in it. Instant Center (IC), blue dot is far away from the COG line. Setup as of right now, the rear is closer to neutral anti-squat. IC, blue dot is close to COG line. Since the picture is skewed a bit, I roughed out the front hub line, since I run a little caster. The rear lower link mount hole on the skid is behind the screw you can see on the side. That just secures the skid to the chassis. Last edited by Szczerba; 12-28-2011 at 09:57 AM. | |
12-27-2011, 09:02 PM | #150 | |
Pebble Pounder Join Date: Sep 2009 Location: Canada
only a vague idea of what you're drawing here. Interested in knowing more. please explain. | |
12-27-2011, 09:52 PM | #151 | |
This picture might help . | |
12-28-2011, 11:48 AM | #152 |
| Re: Szczerba's FF-SZ Just weighed this truck 5lbs RTR Probably going to make up some more weights for the front. |
01-15-2012, 12:06 PM | #153 |
First real outing for the FF-SZ. Truck worked awesome and the driver got lucky Truck handled great. It's a little different getting used to the light weight. It's 5.0 lbs RTR. The siped rovers and Crawler Innovation foams worked good on the slick rock and dirt mix of the ORV park. The 91 spur and Holmes Hobbies 35T TorqueMaster get the gearing to just enough wheelspeed with plenty of torque. I think there will be some Video up before too long. Thanks for the last picture Jacob Last edited by Szczerba; 01-16-2012 at 07:42 AM. |
01-15-2012, 12:29 PM | #154 |
Nicely done. Still trying to decide whether or not I want clapped Rovers. |
01-15-2012, 12:34 PM | #155 | |
Yesterday had alot of slick rock. Bigger lugged tires didn't do so hot. Sedona's were horrible and rovers were decent. Pins on the comp berg worked good but still it was really slick. I think having the lugs cut off helped the tire wad up easier and didn't let the front tires hop around on the lugs when you were trying to get the sides to bite on ledges. The smooth sidewall felt like it grabbed the ledges quicker. The closed cell inner foams also contributed to the grabbing quicker too. Edit. You can see where I have my upper links placed now. I think it's the sweet spot for this chassis/rig. Rears are in top hole. Fronts are one hole from top. Last edited by Szczerba; 01-15-2012 at 01:07 PM. | |
01-17-2012, 07:56 PM | #156 |
Course 1 from ARCC comp. Thanks RolandRockShop for the video. http://www.youtube.com/watch?v=6mxZT...&feature=share Won't Embed! Last edited by Szczerba; 01-17-2012 at 08:01 PM. |
01-18-2012, 07:57 AM | #157 |
Now that's how it's done Shane, nice Sporty rig you have there it looks wicked. Keep an eye on Ashton if he hadn't FU that first course he'd be right there to. |
01-18-2012, 08:00 AM | #158 |
| Re: Szczerba's FF-SZ |
01-18-2012, 08:18 AM | #159 |
You guys are quite the pair those Sporties you guys have are both amazing. I was glad to see you right there keeping Shane a honest guy if you give him a inch he'll take a mile. |
01-18-2012, 08:31 AM | #160 |
Ashton made a poor tire decision with the sedona's on the first course. I mentioned to him several times before the comp how slick the rocks were. Dang kids don't listen these days. Wait for course 2 video, it gets better. |
Szczerba's FF-SZ 2.2s - Similar Threads | ||||
Szczerba's F-Toy #744 | Szczerba | 1.9 Scale Rigs | 240 | 02-17-2022 08:32 PM |
Szczerba's JK (Minus some doors) | Szczerba | G-Made Crawlers | 193 | 11-06-2012 07:26 AM |
Szczerba's Trophy Truck Build.. With Videos | Szczerba | Non Crawler RC's | 110 | 07-18-2012 09:34 PM |
Was Szczerba's Defender 90 Build. On to the Next. | Szczerba | 1.9 Scale Rigs | 22 | 07-07-2012 05:18 PM |
Szczerba's Cherokee (Minus some doors) | Szczerba | Axial SCX-10 | 166 | 03-25-2012 07:45 PM |
