10-12-2012, 06:48 PM | #441 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
Thanks guys I will stick to my servo winches till it's my turn on the quicksand winch list. Love the builds defiantly make for a sexy ultra4 rig. |
10-12-2012, 09:38 PM | #442 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| Re: JIA's IFS Ultra4 build |
10-13-2012, 03:13 AM | #443 |
Couple of interesting shots. The IFS has a sway on the rear. No sway on the rear of the SA rig. Both are running the same springs on the shocks, but the IFS has stiffer pre-load springs. More tire tread on the ground. That's normal with IFS suspension, but there's no big loss of center clearance like people think you'd have. Different tires on for now, but here's a couple of clearance shots. SA rig should get new tires tomorrow. So I'll get another measurement with the larger tires. 4 3/4" 5 1/4" Last edited by JasonInAugusta; 10-13-2012 at 01:14 PM. |
10-13-2012, 12:12 PM | #444 |
Quarry Creeper Join Date: Nov 2011 Location: PDX
Absolutely awesome write up!!! Looking forward to seeing the rig finished, btw I love the tool box with the tv, it reminds me of the one I sold in Houston!!!
10-16-2012, 03:55 AM | #445 | |
| Re: JIA's IFS Ultra4 build Quote:
Cut down some tact switches. Got these at Radio Shack. They're momentary push-buttons that get used in garage door openers and such. Chose mounting locations and drilled holes through the drop-down wheel adapter for each switch. Soldered in a set of Dean's 4R plugs. Soldered the wires to the "wrong" side of the male plug, but it works either way. The only difference is the location of the raised tab on the plug. Buttons are in easy thumb reach. No fumbling about trying to hit switches near the wheel, no need to hold a key-fob transmitter for the winch. What's great about the RC4WD wireless winch controller is that it operates like a 1:1 winch controller. It will only spool/unspool line when you press the button. I prefer this over the 3rd or 4th channel functions on RC controllers that don't give a momentary action when you press the button. Instead it latches and spools line until you hit the other button - and you'd better hope you don't accidentally hit one of those winch buttons unexpectedly. With the RC4WD controller this isn't a problem. Last edited by JasonInAugusta; 10-16-2012 at 12:25 PM. | |
10-16-2012, 11:33 AM | #446 |
That I love! Need to look into that for myself
10-17-2012, 11:46 AM | #447 |
Thanks. The trick is that the RC4WD system is paired to one another. You will only be able to control one winch controller with one transmitter. Of course you can move the controller board from rig to rig if necessary, but since I needed five channels on this build, this setup was the ideal solution. $40 for a winch channel that operates the way a winch should isn't bad. |
10-17-2012, 12:47 PM | #448 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
pretty trick mod Jason. Flawless mount job.
10-17-2012, 05:40 PM | #449 |
Its the only thing I hate about the futaba, I can't get that press on, release off action for the winch. Plus you just freed up another channel for other stuff. I'd assume I could adapt that wireless controller to a servo winch right? |
10-17-2012, 07:36 PM | #450 | |
Ordered some aluminum GPM Exo front arms for this the other day. Today they arrived. Fit and finish is good. They use nylon inserts where the hinge pins pass through the arms so there's no metal on metal. | |
10-17-2012, 07:47 PM | #451 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Hey! I didn't know anyone made alloy arms yet Where did ya order em from? |
10-17-2012, 07:55 PM | #452 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
flea-bay. |
10-17-2012, 08:03 PM | #453 |
Guess they all went to Oahu, 'cause I don't see em |
10-17-2012, 08:23 PM | #454 |
We're waiting on RPM arms too. Slash slipper on an AX2 with 60/12 gearing. |
10-17-2012, 08:31 PM | #455 |
10-17-2012, 08:58 PM | #456 |
RCC Addict Join Date: May 2008 Location: Southern,WV
| Re: JIA's IFS Ultra4 build I ran my servo winch like this. I ran my steering servo to one side of the switch. Then the winch to the other side. So with a flip of the switch I got steering and another flip I got winch all on one channel. |
10-17-2012, 09:03 PM | #457 |
I could have done that but the functions on the 4PKS are all latching. It's either on or off. I much prefer having the winch operate only when I'm pressing the button. That's the way full size winches work - no reason they shouldn't work like that on a small scale. And all of my control is at the radio. No need to flip switches on the vehicle and activate the winch when something else should function. Last edited by JasonInAugusta; 10-17-2012 at 09:05 PM. |
10-17-2012, 09:07 PM | #458 | |
10-17-2012, 09:14 PM | #459 |
Yeah, I just saw this and had to try it. I only have one radio so this setup was a perfect solution for what I needed.
10-17-2012, 09:18 PM | #460 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/388684-jias-ifs-ultra4-build.html | ||||
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - Axial Wraith | This thread | Refback | 03-01-2013 02:33 PM | |
Axial Racing - Project Wrexo – Bender’s Latest Custom Build | This thread | Refback | 02-18-2013 03:40 PM |
JIA's IFS Ultra4 build - Similar Threads | ||||
Solid axle Ultra4 build | JasonInAugusta | Axial Wraith | 79 | 07-08-2013 09:32 PM |
DTP's KOH IFS Ultra4 | DISTURBIN' tha PEACE | Scale Videos! | 7 | 12-20-2012 09:21 AM |
JIA's IFS KOH Ultra4 Wraith Conversions | JasonInAugusta | Chassis and Suspension | 77 | 11-10-2012 10:27 PM |
IFS axial build | red_zook | General Scale Talk | 6 | 04-28-2012 08:43 AM |
Ultra4/KOH build of doom | Ruff11 | 2.2 Scale Rigs | 14 | 10-10-2011 08:11 PM |
