11-21-2012, 06:52 PM | #521 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
| Re: JIA's IFS Ultra4 build
Do you think Maxx shafts could withstand the power of pro4/AX2?
11-22-2012, 02:00 AM | #522 | |
Rock Crawler Join Date: Jan 2007 Location: UK
| Re: JIA's IFS Ultra4 build Quote:
Just FYI: RC4WD Rear Drive Flange Wheel Nut Cover | |
11-24-2012, 01:00 AM | #523 | |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| Re: JIA's IFS Ultra4 build Quote: BTW, these drive flanges are usually seen on steering axles. The description has them listed for rear axles. http://www.pirate4x4.com/tech/billav...60/index3.html Last edited by JasonInAugusta; 11-24-2012 at 01:04 AM. | |
11-24-2012, 01:10 AM | #524 |
| Re: JIA's IFS Ultra4 build |
11-24-2012, 01:12 AM | #525 | |
Broke down last night and did some wiring on a totally unrelated project - got the FPV stuff wired on the quadcopter. The geek work helped clear my head. | |
11-24-2012, 08:45 AM | #526 |
Rock Crawler Join Date: Oct 2012 Location: Vermont
I read through every page of this thread, awesome job. I love attention to small detail - it makes me happy inside.
11-24-2012, 01:09 PM | #527 | |
| Re: JIA's IFS Wraith build Quote:
11-24-2012, 03:00 PM | #528 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
11-24-2012, 03:28 PM | #529 | |
Slash slipper fits right on. | |
11-25-2012, 12:05 AM | #530 |
The ONE piece I've been waiting on so I can wrap up the wiring on this thing has been built. Should be here next week. Switch panel from Overkill RC. |
11-25-2012, 08:36 AM | #531 |
RCC Addict Join Date: Jul 2006 Location: Pasadena
Custom light controller? are the 5 clear pieces indicators?
11-25-2012, 10:24 PM | #532 |
Quarry Creeper Join Date: Jun 2006 Location: Aurora, CO
JIA, if someone wanted to build an Ultra4 rig using both the front and rear independent suspensions from an Exo, what mods would you recommend to the stock Exo suspension to give it better performance for the slightly rockier terrains, without compromising too much stability for trails and speed runs?
11-26-2012, 01:38 AM | #533 | |
| Re: JIA's IFS Ultra4 build Just a switch panel. I've got four light circuits, five if I count the rear amber and brake lights. I'll most likely use that panel for the lights and the other two switches to turn on the BEC circuits. The clear pieces sit on LEDs that are under the clear units and transfer light up through them. Here's a video of Norm's switch panel in his FOJV build. http://s265.beta.photobucket.com/use...b7fff.mp4.html Quote:
Just remember that the Exo steering is fine at speed, but when you slow down and hit the rocks you'll find yourself wanting more throw when you get in tight spots. That's why I'm running stout servos and rear steer. The Hitec 7980 will hold the rear axle straight while hauling and has plenty of power when I want it to turn. The 7980 is slightly larger than a standard servo - the 7950 has almost the same power as the 7980, but fits in a standard servo location - like the stock Exo steering servo mount. Last edited by JasonInAugusta; 11-26-2012 at 01:42 AM. | |
11-26-2012, 02:44 AM | #534 |
Just the shocks and sway bars will give it the proper clearance and travel characteristics for crawling? Would there be any difference in the suggested motor/ESC combo to one of these IFS Wraiths, considering the slightly different suspension?
11-26-2012, 05:06 AM | #535 | |
As far as clearance, I'm not sure if you're talking about just using an Exo and converting it with the full chassis or what. The steering posts mount on the plastic underguards. With the Pro-Line Slash rears the IFS doesn't bottom out. The shocks will reach full compression before the chassis digs in. The motor/ESC is up to you. After using the Pro4/AX2 everything else just seems weak to me. I run my IFS rig on 2S and it's fast. Other guys here are running 3S and love it. I went to 3S in Fat Girl with a 3300kV Pro4 (AX10 transmission) and when I come up the curb into the yard I'm landing 11ft later. If it had a 2-speed it'd be nuts. You end up with both lower and higher gear ratios over a stock Wraith trans. | |
11-27-2012, 01:56 AM | #536 |
At least to start I'd probably be sticking with the stock Exo chassis and cage to keep things simple/cheaper. It'd likely evolve from there though, once I had a proof of concept using just the suspension mods you suggested.
11-27-2012, 05:00 AM | #537 | |
Was on the phone late tonight. Put the earbuds in and worked while I was kept up. With the on/off switching for the LED bars sorted out (HUGE thanks to Overkill RC), I'm working on routing all the cabling and getting all of the electronics packaged in the rig so they're hidden. Trying to plan things so I can actually do maintenance on the thing if/when I need to. I plan to spend tomorrow routing everything, cutting wires to length, soldering all the connections, and terminating the ends for proper connectors. I don't need 30+ feet of cabling in this thing. Last edited by JasonInAugusta; 11-27-2012 at 05:06 AM. | |
11-27-2012, 10:33 AM | #538 | |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
11-27-2012, 11:38 AM | #539 |
Rock Crawler Join Date: Nov 2009 Location: Wasilla Alaska
Be sure to post some pics after your done with sorting out the wiring please.
11-27-2012, 02:26 PM | #540 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/388684-jias-ifs-ultra4-build.html | ||||
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - Axial Wraith | This thread | Refback | 03-01-2013 02:33 PM | |
Axial Racing - Project Wrexo – Bender’s Latest Custom Build | This thread | Refback | 02-18-2013 03:40 PM |
JIA's IFS Ultra4 build - Similar Threads | ||||
Solid axle Ultra4 build | JasonInAugusta | Axial Wraith | 79 | 07-08-2013 09:32 PM |
DTP's KOH IFS Ultra4 | DISTURBIN' tha PEACE | Scale Videos! | 7 | 12-20-2012 09:21 AM |
JIA's IFS KOH Ultra4 Wraith Conversions | JasonInAugusta | Chassis and Suspension | 77 | 11-10-2012 10:27 PM |
IFS axial build | red_zook | General Scale Talk | 6 | 04-28-2012 08:43 AM |
Ultra4/KOH build of doom | Ruff11 | 2.2 Scale Rigs | 14 | 10-10-2011 08:11 PM |
