08-23-2011, 01:13 PM | #541 |
08-23-2011, 04:03 PM | #543 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Ive been running 4.1 for a week with no issues. Ive only bench tested the extra channels and mixing but everything seems fine. Ive bashed all week and crawled Sunday and had the Spektrum guys interested in my $35 radio when they have paid $300-400 haha
08-23-2011, 05:52 PM | #544 | |
I got the 3racing winch working on CH4 with the D/R switch with an old Mini LST ESC and a Micro 2S Lipo until the Heyok Hivolt controller gets here but I didn't like how pressing the switch would winch out or in and continue until you click the opposite way so I set the switch to momentary Scroll to d Ch4 (in my case) MOM ( momentary ) NOR NPV the back out. works great and i don't have to worry about winching to far out and reversing the spool or worse winching to far in and breaking the line and hook Also Set up my Summit trans to shift with the Ch3 button. I just set it up like dig and adjusted the endpoints. I think the summit guys would love this as a replacement radio | |
08-23-2011, 07:02 PM | #545 |
08-23-2011, 07:59 PM | #546 |
OK, I have bearings... http://www.overkillrc.com/products.h...roduct=6133907 Temporary install instructions http://www.rctech.net/forum/9041199-post1288.html If you don't have a reamer, a 15/32" drill bit and some fine sand paper may/should work. Drill the hole out to 15/32", take the sand paper and lightly sand pout the inside. Only need to sand off a few thousandths of an inch. (.003). I suggest getting or borrowing a reamer as it'll make a better hole. Also, even though you can get this bearing cheaper, i put the extra money towards future gt3b mods. I am working on getting 12mm drill bits, which will be an option i include with the bearing. |
08-23-2011, 11:04 PM | #547 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
08-23-2011, 11:11 PM | #548 |
| As long as it fits tight and is on center should be fine/ok. But yes a reamer will provide best results, but i have yet to find a decent reamer for less than $20 that will work good.
08-24-2011, 01:13 AM | #549 | |
even comes with a set of lexan scissors http://www.hobbylinc.com/htm/ghh/ghh...source=froogle | |
08-24-2011, 01:37 PM | #550 |
Pebble Pounder Join Date: Oct 2008 Location: Downieville
Ok so how do I program this to ch3 button? added posibility to select DIG instead of channel number at MultiPosition Had this implemented, so you can have 2 positions to swap between your favorite mix positions easily (0% and 40% for ex) Thanks ahead of time for your help. Love my radio but can't get the hang of programming it. |
08-24-2011, 03:32 PM | #551 | |
Just go into the Multi Postion menu, setup your 2 positions. Then set it up in your key mapping. I have not done this and i currently don't have a GT3B so i can't be much help, besides showing you the multi position part of the manual Code: - mixes 4WS, DIG, throttle brake cut-off (for boats with forward-only throttle), Multi-Position (to set arbitrary up to 8 positions) > choose menu EPOINT and press ENTER-long > menu EPOINT will blink > select one of mixes 4WS (4), DIG (d), brake cut-off (b), multi-position (P) ... for Multi-Position: > press ENTER and choose channel for this function or OFF > press ENTER and set channel value for first position > press ENTER and set channel value for second position or END > ... up to eight position Choose MPO instead of CHn, DIG, 4WS, etc. when mapping it to the keys | |
08-28-2011, 04:23 PM | #552 |
How do ya'll think the count down timer should be implemented. And give specifics, where it'll go on the screen, how to program it, and how to control it. Also i'll have bearing instructions up here in afew days i hope. |
08-28-2011, 04:34 PM | #553 |
Quarry Creeper Join Date: Jul 2008 Location: Sedro Woolley
iam not sure if this belongs in here but hve you figured out how to be able to run the radio off of 2 or 3s lipos instead of the 8 aa batteries?
08-28-2011, 04:44 PM | #554 | |
On 2s, don't go below 6.5 volts, thats the min for the volt regulator. You can drop below 6.5 volts but your voltage reading will no longer be accurate, and shouldn't do it unless you have too. Here's the link to the VR http://www.overkillrc.com/products.h...roduct=5851481 and install instructions http://www.overkillrc.com/GT3B/GT3B%...all%20v1.0.pdf | |
08-28-2011, 05:13 PM | #555 |
how do i go about adding a deans or jst plug so i can hook the battery up?
08-28-2011, 05:16 PM | #556 | |
It'll be fairly difficult to find a 3s that will fit in the box, just an fyi. Theres alink to afew of them a few pages back. | |
08-28-2011, 09:48 PM | #557 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
| I took the tray completely out only to find it doesn't let the battery cover stay on right. I have been running an efite 1000mah in mine and love it. Super light and Small. It gives me a good week or more of use. I also run my gen ace 450 in there on comp days. Makes the radio uber light and I have enough room if I want to carry 2 extra batterys with me in there. Can the timer go anywhere on the screen or just a place that currently has something there? Like could it go above where it says model number? I would like to be able to use my ch3 button switch to start and stop it. Or map it to any button i guess but 3ch button for me. And a long press to restart it. Also count up and down might be nice also
08-28-2011, 10:01 PM | #558 |
Hah, I happen to have a few Genace 2S and 3s 450's and noticed they fit nicely inside. I never connected them to see what the runtime is though. for my batteries I just use the rechargeable 2200mah AA sized cells. They are great because they have a low discharge over time. they are a little fatter than AA's so its a little bit tight but its no biggie. http://www.hobbypartz.com/77p-rechar...2200-8pcs.html |
08-29-2011, 06:05 AM | #559 | |
I wanna be Dave Join Date: May 2006 Location: akron
http://www.hobbypartz.com/83p-1300mah-3s1p-111-15c.html | |
08-29-2011, 02:56 PM | #560 |
Newbie Join Date: Jun 2011 Location: Newfoundland, Canada
I'm having a little trouble hacking mine. On the last step of the instructions it says to go to program and then current tab. But when I do this I get a pop up saying "Cannot communicate with the board, Wrong board selection or check board power supply or check that a previous session is closed" So I tried what it said but still cant seem to make it work, any idea how to fix this? Thanks |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
