![]() | #441 |
Newbie Join Date: Apr 2013 Location: Illinois
It looks like it would be a no.3 taper.
![]() | #442 | |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
| ![]() Quote:
I have seen very expensive air piping systems reduced to scrap from the introduction of synthetic oil. The manufacturers of synthetic oils have to meet lubrication specs that don't account for the formula or additives in the oil. What is really nice is they can change formula anytime as long as the lube specs are still met. ![]() Petroleum based oil is at least that, petroleum. | |
![]() | #443 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Need to drill a 7/64 hole through 1/4 thick hardened tool steel. Will a carbide 4 flute end mill do it? Or, what do you guys recommend?
![]() | #444 |
Quarry Creeper Join Date: Dec 2010 Location: Gaffney
Carbide endmill should do the trick. Just take your time and nake sure its a center cut endmill.
![]() | #445 |
![]() | #446 |
Yashua ![]() Join Date: Sep 2010 Location: Learn the parable of the fig tree
And plenty of lube.
![]() | #447 |
Rock Crawler ![]() Join Date: Mar 2011 Location: USA
Turning the cutting tool slowly ,not to create any heat ,using a good cutting fluid... Back out and clean repeatedly,, ![]() |
![]() | #448 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
Anybody here have a revo end and a set of verniers or mics handy? I need to know the width of the ball.
![]() | #449 |
![]() | #450 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
.273-.274" ish.
![]() | #451 |
Thanks alot! Im working on a chassis at work and i forgot to grab one before i left
![]() | #452 |
![]() | #453 |
Rock Stacker Join Date: Aug 2012 Location: Portugal
![]() | #454 |
Sick! I love the look of that wheel
![]() | #455 |
Thank you men, i'm really liking this design
![]() | #456 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Nice arny ![]() |
![]() | #457 | |
| ![]() Quote: | |
![]() | #458 |
hello, single flute 2mm diameter something like this one |
![]() | #459 |
I'm assuming that's to eliminate tool changes? I like the video! How did you secure the blank to the table, and how did you center the X and Y axis? |
![]() | #460 |
I made a hole in the wood and saved the coordinates of the center of the hole, when I want to make a wheel I go to that coordinates and zero the machine, the gcode is zero in the center. I use thin double sided tape to scure the blank, i'm using the 2mm to avoid tool change, I can make all the wheel with this tool, turn to other side, machine and after that change to drill 1.75 to drill the holes to fix beadlock. |
you Machinists can probly appreciate this... | STANG KILLA SS | Tools, and Procedures | 41 | 05-14-2011 12:59 AM |
Machinists..... | mrpink | Chit Chat | 1 | 08-30-2010 08:31 PM |
Question for the machinists out there... | scally6 | Chit Chat | 12 | 12-03-2009 08:25 PM |
Machinists...opinions? | JasonInAugusta | Tools, and Procedures | 5 | 07-23-2007 11:00 PM |
