08-04-2011, 09:55 PM | #381 |
| No, it needs atleast 6.5 volts..
08-04-2011, 09:57 PM | #382 |
08-04-2011, 09:59 PM | #383 | |||
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
what you do is buy 2 2s cheap zippy packs and call it a day. | |||
08-04-2011, 10:03 PM | #384 | |
It can be over 12 volts...problem with a 2s is the low power alarm min is 7.5 volts and the vr requires 6.5 volts to output 5v's. I'm not sure how people are fitting 3s packs, but they are. | |
08-04-2011, 10:10 PM | #385 |
Just ordered VR. Thanks again Austin and let me know when they are shipping. You gonna post short write up on this mod too? Im sure you are getting more busy each day eh? |
08-04-2011, 10:11 PM | #386 | |
Hmmm ill have to check around and figure that out. Maybe 2s and a 1s in series? Or maybe splitting case on 3s and un folding it flat? Hell i donno LMAO just measured it out. Height 18mm (at ends) 19mm (in center) width 57.5 mm (thats the opening, could be slightly larger if fit in at an angle) length 110 mm Last edited by JokersWild; 08-04-2011 at 10:20 PM. | |
08-04-2011, 10:23 PM | #387 |
LiPo Battery Pack - 1250mAh 3S 11.1v 30C (Rhino R1250-30-3) [81-050] Capacity: 1250mAh Constant discharge: 30C Burst rate: 40C (15sec) Configuration : 3S 11.1v Pack size: 99 x 34 x 17mm Weight : 113g Zippy flight (back ordered at HK) Spec. Capacity: 1600mAh Voltage: 3S1P / 3 Cell / 11.1v Discharge: 20C Constant / 30C Burst Weight: 122g (including wire, plug & shrink wrap) Dimensions: 102x35x17mm Turnigy TX pack Capacity: 1450mAh Voltage: 11.1v (3S1P) Size: 93x40x14mm Charge Plug: JST-XH Discharge: Futaba & JR this one is 2mm taller than case. Not sure if it would fit..... would be tight Rhino 1550mAh 3S1P 25C Lipoly Pack Capacity: 1550mAh Constant discharge: 25C Burst rate: 37C (15sec) Configuration : 3S 11.1v Pack size: 95x35x22 Weight : 137g Last edited by JokersWild; 08-04-2011 at 11:20 PM. |
08-04-2011, 10:28 PM | #388 | |
But yea once i have em i'll write up instructions, much like the fw hack kit instructions. | |
08-04-2011, 10:32 PM | #389 |
Pebble Pounder Join Date: Aug 2009 Location: taiwan
08-04-2011, 10:32 PM | #390 | |
08-04-2011, 10:36 PM | #391 | ||
08-04-2011, 11:04 PM | #392 |
I was thinking using 3 of these cells Higher quality http://www.dealextreme.com/p/soshine...ery-pack-28678 Lesser quality http://www.dealextreme.com/p/trustfi...s-2-pack-20392 |
08-04-2011, 11:32 PM | #393 | |
Hell since they come in sets you could just buy six. Make 2 3cell packs and toss em both in there and swap out plugs when one dies | |
08-04-2011, 11:40 PM | #394 | |
But yes they'd be connected like nihm packs, i'm looking for a 18650 holder though as it may be easier...but i've seen one that holds two, and one that holds 4 No 3 I don't think the batt box can hold 6, maybe shove them up in the handle | |
08-04-2011, 11:57 PM | #395 |
well i found premade holders...15 bucks apiece :shock
08-05-2011, 12:04 AM | #396 | |
08-05-2011, 12:38 AM | #397 |
08-05-2011, 01:08 AM | #398 |
I forgot to mention, the vr's will come with some doubled sided tape (3/8" adhesive dots) so you can stick the vr on so its easier to solder
08-05-2011, 03:07 AM | #399 |
08-05-2011, 05:16 AM | #400 | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
